Author Topic: sst49lf160c  (Read 188 times)
Offline sagiasTopic starter
  • Country: gr
sst49lf160c
« on: September 24, 2024, 06:27:09 am »
Hello guys i want to programm an sst49lf160
but my tl866ii plus dont support the ic,
i want to know if i can find a suitable programmer i googlebut nothing found
thanks
Offline stj
Re: sst49lf160c
« Reply #1 on: September 24, 2024, 09:21:07 am »
firstly i think you got the part number wrong or it was changed,
i can only find references to 49lf016c
T48 supports it.
but if it's a parallel flash then you may be able to program it as a 49lf080 in 2 banks by manually manipulating the highest address line.
Offline ftg
    • ftg's RF hax paeg
Re: sst49lf160c
« Reply #2 on: September 24, 2024, 11:48:51 am »
The -f160 Flash chips seems to be a weird in-between model that was not often used.
So older and newer chips with different cases and pinouts are often supported, but f160's not.
