Author Topic: interfacing TENMA 72-7730 to pc with V3.00  (Read 2211 times)
Offline FrankT1965Topic starter
« on: January 28, 2021, 02:30:23 pm »
anybody here who tried to connect the TENMA 72-7730 multimeter to a windows 10 pc running the pc interface software V3.00?
I am still trying to get it connected - no luck so far.
I need to record an electrical current for a few days with on off periods of 90min an 270 min
kind regards
Online Kean
    • Kean Electronics
Re: interfacing TENMA 72-7730 to pc with V3.00
« Reply #1 on: January 29, 2021, 11:22:36 am »
Yes, I have it working - at least on a 72-7730A.
Did you enable the SEND mode by holding down MAX/MIN button for 2 seconds?  Pressing EXIT will turn it off again.
The one bug I see is if data reception times out, then you may have to click "USB Disconnect" to reconnect again.
Online HKJ
    • Tests
« Reply #2 on: January 29, 2021, 04:14:44 pm »
Not all software will log for a few days, you may also have have problems with the battery lifetime.
TestController can easily do that (can also do a few weeks) and I do support 72-7730 (I hope, it is based on another meter that is supposed to be the same).
https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/
Online Kean
    • Kean Electronics
« Reply #3 on: January 29, 2021, 04:26:35 pm »
Excellent - I've been meaning to try it out myself.
