Author Topic: Recommendation for a 300V DC power supply  (Read 2406 times)
Offline davorinTopic starter
« on: October 25, 2015, 01:40:16 pm »
As one of my many Hobbies is to restore old vacuum tube Radios....which DC power supply would you recommend which can go up to 270 - 300V DC and deliver 0.15A?
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
Re: Recommendation for a 300V DC power supply
« Reply #1 on: October 25, 2015, 01:55:27 pm »
As far as used supplies go, you might try looking for a Heathkit IP-17 or an HP 711A.  Both are only good for 100mA continuous output so they don't quite match your specs, but they do show up occasionally on eBay.  The Heath goes to 400V; the HP to 500.  I don't know how common they'd be in Europe,  nor how much shipping might be from the US, but there are two possibilities at least.
-Pat
Online Alex Eisenhut
  • Place text here.
« Reply #2 on: October 25, 2015, 02:22:50 pm »
http://www.ebay.ca/itm/DC12V-24-to-DC-200-450V-70W-high-voltage-converter-boost-step-up-power-supply-/181746908549?hash=item2a50f5bd85:g:uykAAOSwv0tVVvMh
This is close. I bought the lower voltage one and it delivers the juice, but I haven't looked at the ripple/noise of the output.
Offline Gyro
« Reply #3 on: October 25, 2015, 04:05:22 pm »
I was going to say you could buid your own cheaper, but having seen the cost of the converter in the previous post...  :o
Anyway, here's the link:
http://sound.westhost.com/project151.htm
EDIT: The linear one might be quieter though.
« Last Edit: October 25, 2015, 04:07:30 pm by Gyro »
Best Regards, Chris
Online nctnico
« Reply #4 on: October 25, 2015, 04:19:14 pm »
I don't like the switching converter. In a lab supply you'll want current limiting and no smoke when it is overloaded.
