Hello,
I've done quite a bit of research, searched the forum, read the stickies, perused the spreadsheet. But I haven't been able to hone in on exactly what meter I should be looking at.
I'm in Canada if you couldn't tell from the title. Can purchase anywhere in NA.
Primarily do audio work. Lots of vacuum tubes, some transistor. Not really any "modern" needs.
I'm looking for a meter with:
- 1KV rating (frequently measure 700V+)
- mA range
- True RMS
- Continuity mode is a + (understand not many bench meters have this, not a dealbreaker but would be nice)
- Ease of calibration and repairability (Looking to keep for a lifetime, not replace after a few years)
- Smaller form factor is better, space is always an issue. Not a deal breaker if larger though.
I'm looking for something that's all in one, I can use in service everyday, but is also useful for calibrating other equipment. I just aligned my Tektronix 577 with my Fluke 179, and while accurate enough for my needs, more accuracy would have been better. The form factor of a bench meter would be great in my shop. Get it up on the shelf and off of the bench.
I enjoy old stalwart, well made gear that's well designed and has stood the test of time like the HP200 oscillator, for example.
I am flexible on budget but would prefer to keep under $500CAD/$400USD.
Any suggestions as to what I'm looking for?
Thank you in advance!
