Hey Gramo,
Both the Otii Arc and the Otii Ace from Qoitech are great alternatives for what you shared. The decision between the two is mainly based on the measurement ranges, accuracy, and support for additional features in the Otii Software. So, Otii Ace would be the best choice to cover all the new features, even the upcoming ones. Here you can see a technical comparison that may be useful:
https://www.qoitech.com/hardware/Keep in mind that Otii previously had a Pro license for the software, and since months ago, it is no longer required – it's FREE now. Here you can see all the details:
https://www.qoitech.com/blog/license-model/With Otii, you can both power your device under test and measure current, power, and voltage channels for the entire system or subsystems (sensors, communication modules, actuators, etc) by making use of the additional pins available, which also has an external power supply that can go up to 15V, with an isolated ground in the case of the Otii Ace. In addition to the measurements, you have various tools to visualize, analyze, zoom and investigate the recordings in detail, including the possibility of debugging your code over UART.
In case you are interested, below there is a Quick Start series that walks you through the first steps, as well as some use cases:
https://www.qoitech.com/usecases/Nevertheless, Otii Product Suite goes beyond measuring devices. It is a compact and flexible tool that can be adapted to other uses. For example, profiling and emulating batteries/PV cells based on the performance of your device under test, as well as automating device measurements and battery emulations for device verification.
I highly recommend to check. I am biased, but here to help!
