Author Topic: Reasonably priced differential probes  (Read 56497 times)
Offline McBryceTopic starter
« on: April 07, 2015, 08:04:56 pm »
Hi all,
     I'm looking to buy a differential probe without having to spend a fortune. I only need to test up to 240VAC, so I don't need a fat 1000V device. Happy to buy some Chinese device too as long as it is safe for me and my scope.
Any recommendations?
McBryce.
Online nctnico
Re: Reasonably priced differential probes
« Reply #1 on: April 07, 2015, 08:21:59 pm »
Look on Ebay for the brand Pintek (Made in Taiwan).
Offline AndyC_772
« Reply #3 on: April 07, 2015, 08:55:25 pm »
Thanks, I'll check those out.
McBryce.
Offline kripton2035
« Reply #4 on: April 07, 2015, 09:36:02 pm »
I have one of these:
https://www.picotech.com/accessories/active-oscilloscope-probes/25-mhz-700-v-differential-probe
also have one of these, bought used on ebay for some 100€ some 5 years ago
there are from time to time on ebay in europe , just be patient.
Online nctnico
« Reply #5 on: April 07, 2015, 10:25:07 pm »
One of the things to decide on is whether to get a mains powered or battery powered diff. probe. Since I hate having test equipment with batteries I choose to buy a mains powered diff. probe.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #6 on: April 08, 2015, 12:04:45 am »
thats what you need, the fat 1000V device. 240Vac is ±330V or 660Vpp (differential), 1000V is the best and safer margin you can get. you seldomly see 660V devices.
Offline bson
« Reply #7 on: April 08, 2015, 12:40:30 am »
BitScope also has a sub-$300 differential probe... http://my.bitscope.com/store/?p=view&i=item+7
1.3kVpp, 25MHz, 9V battery or external DC adapter.
Offline Someone
    • send complaints here
« Reply #8 on: April 08, 2015, 05:06:04 am »
The peak withstand voltage for 240V mains in Measurement Category II (CAT II) devices in 61010 is over 2500V peak (I don't recall interpolation being allowed in that table).
Reputable scope manufacturers already include this allowance in their probing solutions. Tek provide clean URLs so we can use them for example:
http://www.tek.com/passive-probe
http://www.tek.com/oscilloscope-probes-and-accessories/differential-probe-high-voltage
The popular P5205A has a measurement range of +/- 1300V (differential or common mode), but carries a rating of 1000V CAT II. It will protect from transient over voltage events, but may not necessarily survive it. The comparable Keysight N2790A specifies a measurement range of +/- 1400V with a rating of 1000V CAT II, but also specifies a non-destructive absolute maximum of +/- 1500V and +/- 1300V RMS CAT II.
Interestingly the P5202A is 300V CAT II with a +/- 640V peak.
Offline mij59
« Reply #9 on: April 08, 2015, 06:14:16 am »
I got  the Testec TT-SI-9001 from Batronix http://www.batronix.com/shop/accessory/probes.html
Offline tautech
« Reply #10 on: April 08, 2015, 07:26:50 am »
Siglent do 2 models:
DPB3050    50 MHz  800V  US$483
http://www.siglentamerica.com/prodcut-fjxx.aspx?fjid=408&id=-1&tid=1&T=1
DPB4050     50 MHz   6.5 kV US$720
http://www.siglentamerica.com/prodcut-fjxx.aspx?fjid=406&id=-1&tid=1&T=1
This one includes a power adapter.
Pricing may be plus taxes if any.
« Reply #11 on: April 08, 2015, 07:46:55 am »
Yes, what I meant is that I only need a lower voltage version (I think most start at about 700V), not one of those 10000V RMS big fat isolated ones that cost a fortune.
McBryce.
Offline electr_peter
  • Country: lt
« Reply #12 on: April 08, 2015, 08:01:40 pm »
Offline dadler
« Reply #13 on: April 10, 2015, 08:15:55 pm »
I looked into these and found this: http://www.ebay.com/itm/300710178863?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
This looks like a decent product with decent specs, but I wonder if it will match my use case.
I am not all that interested in super high voltages, I mainly want ground isolation. Essentially, want to be able to measure the potential between points in a low-ish voltage circuit (under 30v absolute voltage). Right now I can do the subtract-channels thing, but sometimes the result is noisy and I lose the ability to use XY mode and math functions.
Does anyone know if this differential probe in particular will match my use case, used with, say, a DS2072a or DS1054z? The attenuation and resulting low scope input voltages are what concern me, when used in a relatively low voltage circuit.
Online nctnico
« Reply #14 on: April 10, 2015, 08:41:07 pm »
I have the diff. probe from the link above. In the x20 mode the maximum voltage is 35V. This is definitely in the voltage range you are looking for.
Offline dadler
« Reply #15 on: April 10, 2015, 09:28:02 pm »
Ahh I read the specs wrong. Thanks, and thanks for the suggestion. I researched around and found the teardown thread on the forum here and for the price it seems like a good deal.
Just placed an order.  :-+
Offline slurry
« Reply #16 on: April 10, 2015, 09:30:30 pm »
Still...the absolutely cheapest $0 solution is to use the tips of two probes, just inverting one of the channels, voilá  :)
Online nctnico
« Reply #17 on: April 10, 2015, 09:48:06 pm »
That consumes two channels and has severe limitations. You need to have the channels set to accommodate for the full voltage. If you want to look at a 500mV signal on a 30V offset from ground you'll need to set the scope to at least 5V/div which means the 500mV signal is almost invisible. With a differential probe you can set the scope to 20mV/div or 50mV/div and see the full signal.
edit: type
« Last Edit: April 10, 2015, 10:29:53 pm by nctnico »
Offline slurry
« Reply #18 on: April 10, 2015, 10:15:13 pm »
That consumes two channels and has severe limitations. You need to have the channels set to accomodate for the full voltage. If you want to look at a 500mV signal on a 30V offset from ground you'll need to set the scope to at least 5V/div which means the 500mV signal is almost invisible. With a differential probe you can set the scope to 20mV/div or 50mV/div and see the full signal.
True... but the price is hard to beat  ;)
Offline DanielS
« Reply #19 on: April 11, 2015, 08:40:16 am »
Aside from the sensitivity issues mentioned above, that only works if you have perfect gain and timing match between the two channels.
Using the two probes method to measure voltage across a small current sensing resistor (my main use for differential measurements) is nowhere near as clean as using an instrumentation amplifier or equivalent opamp when possible.
  • Country: my
« Reply #20 on: April 11, 2015, 03:52:25 pm »
but the performance is awful, its better to slap few opamps and volt divider into a active differential probe diy circuit. the diy circuit will be awful but 2dso probes setup is more awful.
Offline DanielS
« Reply #21 on: April 11, 2015, 04:51:28 pm »
Instead of slapping a bunch of opamps together, I would try looking at instrumentation amplifiers first: much simpler, far more accurate and possibly cheaper than attempting to match their performance using discrete opamps and precision resistors. You get 80-100dB CMRR with hardly any effort instead of fighting an uphill battle to go beyond 50dB using discretes.
Offline SArepairman
  • wannabee bit hunter
« Reply #22 on: April 11, 2015, 06:23:14 pm »
have you considered old tektronix p series probes? with attenuator.
Offline Keylectric
« Reply #23 on: April 11, 2015, 10:25:45 pm »
Hi, first post for me!
Agilent/Keysight have what seems to be the same product under their brand. A sign of ok quality perhaps if you feel Pico name is not a heavy hitter. Seems to be an ok basic diff probe. Pico pricing is lower.
Offline Fsck
  • sleep deprived
« Reply #24 on: April 11, 2015, 10:36:34 pm »
the OEM is http://www.sapphire.com.tw/
"This is a one line proof...if we start sufficiently far to the left."
