Author Topic: Broke fan collet for 2465 scope  (Read 1191 times)
Offline LootMasterTopic starter
« on: December 05, 2020, 06:40:44 am »
Can anybody print me this or make this for me ?  :palm:
PM me cost.
https://cdn.hackaday.io/files/1638907011869760/2445-2465%20Fan%20Collet.jpg
I recapped the electrolytics, re-assembled all, saw that it worked.
Only to find that this stupid fan would not fit anymore due to it being broken nd apparently its needed.
« Last Edit: December 05, 2020, 07:11:02 am by LootMaster »
Offline Gertjan
Re: Broke fan collet for 2465 scope
« Reply #1 on: December 05, 2020, 07:14:29 am »
You had been warned in your original topic:
Make sure you understand how to remove the fan without the collet disintegrating.
All that is well described elsewhere, so there is no point in us repeating it.
Good luck......
« Reply #2 on: December 05, 2020, 07:39:35 am »
The plastic fused together its been 36 years.
Guess I'm no expert at removing 36 year old fans, blame me....
Even the pros, rarely get it.
https://groups.io/g/TekScopes/search?q=collet
I contacted some people over there, a few of them have lathes/printers and made some.
Just widening my contacts now.
Online tggzzz
« Reply #3 on: December 05, 2020, 09:30:42 am »
I think that is a consequence of the problem, as I've noted here: https://www.eevblog.com/forum/testgear/help-me-refurbish-my-tek-2465-for-a-friend/msg3355342/#msg3355342
The pros do get it - and attempt to impart the information to those with less experience. But there's a proverb: "you can lead a horse to water, but you can't make it drink".
I do have a spare such collet, but it is imperfect. I fear that if I sent it to you and you didn't like it, then I would be subjected to rude comments such as this:
Shut up dude
« Last Edit: December 05, 2020, 09:38:36 am by tggzzz »
« Reply #4 on: December 05, 2020, 10:23:12 am »
Imperfect? Nah, probably wont fit and fall off.
Online tggzzz
« Reply #5 on: December 05, 2020, 10:51:59 am »
It hasn't on one of mine.
« Reply #6 on: December 05, 2020, 12:50:46 pm »
well I would like a metal one if possible?
And not from a working model if possible.
Dont wish to cause a problem now on your scope  :-BROKE
« Reply #7 on: December 05, 2020, 01:11:49 pm »
I have successfully fixed mine with epoxy.
