@Bad_Driver
No, I'm still on the search for the lost nanosecond.
My own little diy gpsdo takes just 1.4W (DC jack input - the wallwart consumes 2.1W from the mains after the ocxo has warmed up). My rubidium frequency standard project only draws 11 watt (LPRO 101 with an Arduino nano controlled fan cooler fed with 19v from a laptop charging brick).
One of the attractions for going the DIY route over using older ready made kit is that you get to have some say in how much energy it'll consume.
In this case, my main concern wasn't about the energy costs so much as thermal consideration of the component temperatures inside of the rather diminutive and economically priced 100 by 100 by 50mm extruded aluminium enclosure I'd chosen to build it into.
When you're already burning some 50 watts (NAS box and its UPS) and another 100 watts on a desktop PC running 24/7 on top of the additional 32W consumed by an ancient APC SmartUPS2000 supplying protected mains outlets around the house, another vampire load or
three four (2W gpsdo, 11W Rubidium frequency reference, 13W SDM3065X and another 22W on an SDS1202X-E, tends to be 'lost in the noise' (not so true for the 54W consumed by the SDS2
1504X+ though).
You touched lucky with those video distribution amps. Every time I've scoured ebay, what few examples there were to be had were all grossly overpriced. I could well land up repurposing the THS3002i I removed from my FY6600 (to get back on topic) to lash up my own 4 channel 10MHz distribution amp if this absence of cheap video distribution amps persists.
Assuming you're going to be using decent capacity (2AH) 18650s that's the same as a laptop battery pack's 43WH's worth of energy storage which could give you a run time of around 7 or 8 hours. Fitting half a dozen 18650s into the case seems a bit of a squeeze to me though. A set of three 4AH pouch cells might be a better option (less weight and volume).
As for the question regarding a +/-13v supply, I've looked into this in the past and couldn't find a satisfactory solution (they weren't cheap or suffered too much ripple noise or both). It's worth keeping in mind that as a general rule, buck converters offer the best efficiency and ripple noise performance, followed by non-inverting boost converters and then inverting buck converters with inverting boost converters taking last place.
IME, trawling through ebay's offerings for cheap inverting buck or boost converters is rather like going on a Unicorn hunt
There's a good reason why those who go the analogue mains transformer / rectifier / smoothing cap route to eliminate smpsu switching noise and ripple issues, tend to go for separate secondaries so they can use positive polarity regulators all round whether they be buck converters or those mini-space heaters labelled 78xx or 1117-xx.
Obviously, you don't want to be using a split battery supply to use the same solution so somewhere between battery and your bi-polar voltage rails, you're going to have to use an inverting converter (buck or boost). Dual rail converters do exist but you're probably going to have to submit a RFQ just to find out the price since I've never seen any on ebay (at least not at a sensible price, if at all).
We have a saying you're probably already aware of that goes "If you have to ask (the price), you probably can't afford it." I've been mindful of this whenever I've come up against such barriers to getting a price on anything so special that it's seemingly only available brand new direct from the manufacturer or their official distributor so never bothered to submit a RFQ, preferring to carry on looking elsewhere until I either get lucky or start losing the will to live and give the whole idea a well earned rest.
You can try searching on ebay, Amazon, Banggood and AliExpress if you don't want to pay full price with official distributors like Element 14. You seem to have had better luck than me in snagging bargains (off ebay at least), so you may be able to track down those elusive (to me) Unicorn parts. Keep in mind that with a 3S2P Lithium cell battery you need to assume a discharge endpoint voltage of 10v in your calculations when choosing DC-DC converter modules.
The latest versions of these FY6900 models have incorporated the +/- 13v converter modules into the main board as you noted, considerably simplifying any diy psu and battery power upgrade projects to just a single 2A 5v psu board or a 2 to 5s Lipo battery pack with one of those mini360 (3A max/2.1A continuous) 5 volt out rated for 24v to 6.5v input converter modules sold by Banggood (and no doubt elsewhere) but that's no help to you (or me!).
Regarding that weather forecast of snow you mentioned, I have a news flash!
The winds here have been been steadily increasing over the evening. A few hours earlier, I ventured to our attic bedroom floor to check on my gps antenna. It was swaying a little wildly but not alarmingly so. I've just taken another look about half an hour ago (2200GMT) and the picture is very different. The 20cms diameter biscuit tin lid I have mounted onto the top of a 3 metre aluminium pole clamped into the corner of a metal drawer ballasted with four expired car batteries sat on the flat bay window roof is now bending a good 45 degrees southward during the heavier wind gusts and, by looking out of the attic bedroom window onto the bay window roof, rather more alarmingly, I can see one corner of this drawer lifting an inch or so during these gusts, despite the weight of a 36AH car battery holding it down!
Only this one corner so far but if the wind gusts get much stronger I can see either the pole torn from its ballasted drawer or else the whole lot tipping over and landing in our front garden by the early morning. That gale proof antenna mounting arrangement is not quite so proof against gale force winds as I'd hoped.
At the very least I'm going to have to rethink my antenna mounting options when the multiband GNSS timing antenna replacement
https://www.aliexpress.com/item/32815205556.html (plus a 20 metre TNC to SMA RG58 patch cable) arrives, hopefully by the promised delivery date in a fortnight's time. I may have to wait until late January though for the one remaining component critical to this upgrade project, namely a 5/8 to 1/4 inch UNC adaptor, to turn up anyway so plenty of time to revamp my antenna mounting arrangement.
In the meantime, the wind strength seems to have abated, confirmed by my local airport's METAR data and a local amateur weather station. I'd observed two or three briefest of mains drop outs (too brief for the UPS to notice anyway) earlier in the evening before venturing out across our road to get a better Idea of how the GPS antenna was responding to the strongest gusts (it didn't look good) when I observed yet another drop out.
After returning to my workroom, there were another two dropouts, this time just long enough for the Backups500 to take notice of and issue a warning beep. There haven't been any further dropouts during the past hour or so, all of which suggests we're now through the worst of the weather.
However, I have noticed another three briefest of barely perceptible dropouts during the past ten minutes, so I guess some part of the high voltage transmission lines must still be taking a beating somewhere in the UK's national grid. Ah well, time enough tomorrow for me to examine the damage and take stock of the situation. There's little I care to do until the weather calms down anyway.
If it's still there after the weather calms down, at least I can reach out of the window and haul the whole contraption back into the room to repair and strengthen it up to face the next gale force / storm strength winds we can expect to see this winter. At least with the current mag mount patch antenna which I'd also glued to the biscuit tin lid which I'll be taking a pair of tin snips to to trim it down to a lighter smaller and more aerodynamic form.
As best as I can figure, the GNSS antenna I've ordered must weigh at least 3 to 4 times more. Its more aerodynamic shape will help mitigate the additional weight to some extent but nowhere near enough to carry on using the existing one inch diameter aluminium pole currently clamped to a, no doubt by now, rather over stressed corner of its metal drawer base. I've still got plenty of ballast for the next improved antenna support contraption and a benchmark to guide its design.
Enjoy your promised snowy weather.
