I found under the heat sink this two non populated IC pads. Does someone has a clue what this could be for?
Different OPs with other footprint? Or another pair of THS3002 to increase load?
Has someone used it? I apologize when this was part of the ongoing disussions and I missed it.
Thanks in advance!
That's an interesting photo you just posted. It looks like someone will
have to reverse engineer
this main board on account it
is radically different from the FY6600 and the FY6800 models as far as the final 12dB boost amp circuit goes.
What's different in the case of the FY6900 is that they've used a
pair of THS3002i dual opamps in place of the single dual opamp used in the earlier FGs. It was a little tricky to make out what that IC in the top left hand corner of the heatsink's keep out area was (I'd been able to positively identify its cousin in the bottom LH corner, a THS3002i). I was surprised to see a second THS3002i chip but the 100 ohm resistors and the FB and Gain resistors rather give the game away.
The unpopulated U21 and U22 are for single higher spec opamps THS 3001/3491/3495 etc. If you have a go at this upgrade, you'll need a pair of the higher spec single opamps to fill the unpopulated spots and remove both THS3002i opamps and strap the 100 ohm resistors now separated by the removal of the 3002i opamps (each one of a pair used these resistors to combine their individual outputs so the load saw a 50ohm source but the outputs were in no danger of fighting each other due to slight gain mismatches - it's a common way to use more than one opamp in parallel to improve performance at higher frequencies).
TBH, I'm rather surprised they'd bothered providing the unpopulated U21 U22 locations on the main board since with a 20MHz upper limit before the 24v pk-pk limit is dropped to 5v (and these opamps switched out of circuit), I'd have thought just doubling up on the 3002i opamps alone would have addressed the horrible distortion on sine wave output at 20v pk-pk at the 20MHz limit exhibited by its predecessors.
Check the waveform at the same 20MHz limit for the 24v p-p option driving 50 ohm loads which should result in a 12v p-p waveform. If it looks more like the 2nd attached image SDS00227 (THS3491 upgrade) rather than the 1st image SDS00163 (the original THS3002i opamps), I wouldn't go to all the bother and the expense of another pair of THS3491 opamps just for a marginal, if any, improvement. There might not be any real need in this case to duplicate the opamp upgrade efforts of the FY6600 and 6800 community.
JBG
P.S. I'm still busy testing my MK II GPSDO (after an initially promising but, ultimately disastrous start - I somehow blew up a 74HC14 and two of my 5v RRO cmos opamps, culminating in the tiny 1.3A mini 360 5v buck converter starting to let out its magic smoke.
I had modded the buck inverter to give me 5.340v (the cmos opamps are rated for 5.5v working but it was the first one that went short circuit and cooked the buck inverter's goose). I landed up trying out my one and only example low noise 5v buck converter with 5v LDO in place of the burnt out one simply on account it had the same pin out footprint and it seemed a convenient way to test the claimed "Best of both technologies" most of the efficiency benefit of a switching regulator with an LDO to get rid of the switch noise (yeah, like that's gonna happen
I haven't gotten round to checking this low noise buck/LDO chimera's noise and ripple yet - I've been rather busy fettling my now functioning GPSDO board. The latest experiment involved a test with ten times the 500 seconds TC (replace the 100K and 1M resistors with 1M and 10M - I couldn't find another 5.6M in my collection but I had a few 10M resistors
As you could imagine, it took way longer to lock the OCXO - around 3 1/2 hours versus the 25 minutes with the 500 seconds TC !!! Fortunately, I have a simple circuit add on which should shave a couple or more hours off that startup time which I hope to put to the test later today.
[EDIT 2020-07-09]
That "Low Noise best of both worlds buck/ldo" module exceeded my expectations of decrepitude, largely I suspect due to the use of an unshielded inductor. Also, my simple two diode (one for each of the 470 and 47uF TC caps) plus a 5K trimpot accelerator circuit did solve the slow startup issue, shaving some 3 hours off the original 3 1/2 hour lock up time.
I also finally got round to matching up a set of 5 1K resistors to create a selection of 5 voltmeter offsets in 1v steps from zero up to 4 volts to let me use the mV range on a cheap (13 quid) Mestek 9999 counts DMM to monitor the VFC in tenths of a mV using the OCXO's 5.127v Vref to provide an extremely stable voltage source (far better than the TL431 I used to create a 3v meter offset in the MK I).
The motivation to finally get off my backside and install this reference source came about as a result of my using a part used but well rested AA alkaline cell as an initial temporary measure to monitor the MK II's VFC in 100uV increments after the
apparent VFC started bucking the trend of a rising voltage with age exhibited by the 13MHz OCXO used in the MK I which proved to be the AA cell starting to increase its voltage output about 1 mV per day
I hadn't taken note of the AA cell's initial voltage so wasn't able to work this out until after directly monitoring the 2.282v VFC for a couple of days to confirm it wasn't actually dropping at all (at least at nowhere near the rate implied by my AA cell voltage offset lash-up).
Lithium coin cells are a much better bet on voltage stability for such a stunt provided the 3.16 or so volts gets you close enough to allow a cheap 3 1/2 digit DMM to use its mV range and show readings to tenths of a millivolt. Here, absolute accuracy whilst nice to have, is not essential - it's the weeks long stability of a CR2032's open circuit voltage that counts (worst case drain with a 10M DMM input is just 100nA, in my case it had been just 15nA or so with the MK I and a CR2032).
