Your first attempt at interacting with this Forum is this Thread started by a mystery Member spruiking for you! You didn't even have the decency to start your own thread.
https://www.eevblog.com/forum/testgear/feeltech-fy6600-60mhz-2-ch-vco-function-arbitrary-waveform-signal-generator/
Start at the beginning and read the content and try and repair why we should think kindly of you and not think you are PATHETIC in your companies behaviour!
You are the MANUFACTURER of the product and the failures start and end with you with your reseller being in the middle with generally zero technical skills or knowledge. Then to blame them for your poor product is worse than pathetic! Using them as sacrificial pawns is beyond pathetic.
1. We hope you can give us detailed questions about the inferior quality of the products, and we can help you solve them. We would like to thank you very much for your suggestion. FeelElec wants to bring customers a better product experience.
2. FeelElec have never attributed the responsibility to the agent, the agent feedback to our company's problems, we will respond within 24 hours, and actively assist the agent to help customers solve problems.
3. From now on, there will be someone in charge of the forum account. We are willing to receive more feedback from customers and suggestions. We also have the ability to solve any problems in our products, provide better services for users, and develop more products that users like. Better help distributors sell our products!
4. Any questions about product quality or special functional requirements you may encounter before or after can contact us directly in eevblog.
After-Sale Email Address: service@feelelec.com
Save your platitudes for someone gullible enough to believe them
After 4+ YEARS YOU were still producing units with sub par power supplies and were no doubt very aware of that fact! 90V of floating supply is So many other threads but I won't bother adding them all here.
https://www.eevblog.com/forum/testgear/feeltech-fy3200-psu-upgrade/msg965575/#msg965575
Completely inadequate and PATHETIC response to some of YOUR CUSTOMERS directly and or via resellers not being able to come together to resolve major failures of FY6600 units. https://www.eevblog.com/forum/repair/reflashing-or-resetting-a-feeltech-fy6600-signal-generator/ In a similar manner I won't bother to list all examples but trust me they are MANY! Members of this Forum were left with non functioning units. True some were resolved but most went unsolved!
And in the main FY6600 thread so many partial failures of displays or certain waveforms and yet no upgrade or remedy path to repair them!
Clearly you only want to waffle platitudes and Feelgood about moving forward and have us whitewash you very grey past.
Until you face up to your past you don't deserve a free pass to your future.
We dono’t want to cover up the problems existing in the previous products, just want to be able to better serve customers and solve customers'problems.
As for the FY6600 malfunction encountered by our customers, now contact us, we will still actively solve the problem for our customers.
Regarding the power supply, the answers are as follows:
First of all, in the absence of the introduction of the ground wire of the two-wire plug of the switching power supply system will have such a situation.
In order to suppress common mode interference, the switching power supply in the design, the "Safety ceramic Cap" will be between the "LG / NG" (Safety Ceramic Cap is used for such occasions, even if the capacitor fails, will not lead to electric shock, so the secondary side of the switching power supply "ground" is equivalent to the midpoint of the AC voltage, so you measured 110V voltage. But this does not mean there will be security risks, after all, the capacitance capacity of only 1000pf.
If you are still worried about its leakage, then the correct way is to measure its DC leakage resistance, the use of insulation tester is the most effective way
And we responded in 2017 as well,
https://www.eevblog.com/forum/testgear/feeltech-fy6600-60mhz-2-ch-vco-function-arbitrary-waveform-signal-generator/msg1297231/#msg1297231The following figure is the official shooting of Apple Power Supply. You can see that the suspension voltage is 55V, which does not mean that the quality is problematic.
