Author Topic: Re: FeelElec New Arrival FY-6900 Signal Generator  (Read 176530 times)
Offline Nobody4356
  • Country: th
« Reply #675 on: February 07, 2023, 12:42:59 pm »
On windows 11 64bit, the same "Runtime error 380 - invalid property value"
Offline RUS
« Reply #676 on: March 07, 2023, 01:25:29 pm »
In my FY 6900-60, firmware of  flash FPGA  broke. I wrote to FeelElec  - I received no answer. I tried the firmware from  FY 6600 - it does not work. Firmware of control panel 1.3.1   What to do? :-[
Offline sathunter
« Reply #677 on: May 22, 2023, 04:23:59 pm »
FY6900-60M
For anyone keeping track of the variants, I received a FY6900 today (Banggood) with:
* 5V power supply board V1.32
* main board V3.31 with  "AN_EG4D20EG176"
* front board V2.2
* firmware V1.5.3
« Last Edit: May 22, 2023, 05:08:11 pm by sathunter »
Offline DaneLaw
« Reply #678 on: May 23, 2023, 11:39:39 am »
Also got mine from Banggood (EU store) though in early 2020 when they were clearing EU-stock at a heavy discount. [FY6900/60MHz]
Generally just use it with power bank or the scopes 5V USB out (for most use cases) as the wiring from the PSU, seems to center around 5V on my unit.
// Anybody fitted batteries in these units, with a crude charge & buck/boost circuit?
[PD3.1 140watt in/out pr socket powerbank, but can run from more or less' any power bank as the wattage draw is quite low]
Choked that annoying squeaker for a more pleasant "I got it" feedback, instead of toggling it off.
btw, did anybody have rise&fall adjustment on any of the FY6900 software versions, as seen on the FY6800.?
https://www.eevblog.com/forum/testgear/re-feelelec-new-arrival-fy-6900-signal-generator/msg4305757/#msg4305757
// 4:17 rise/falltime adjustment by double pressing the duty.??
« Last Edit: October 26, 2023, 06:50:41 pm by DaneLaw »
The following users thanked this post: PinheadBE
Online Aldo22
« Reply #679 on: June 12, 2023, 11:02:20 pm »
Hi
Does anyone know the 40MHz variant FY6900-40M?
Is it from Feeltech or is this something else?
It does not exist on the Feeltech website.
What is that?
The following users thanked this post: Bravo
Offline PinheadBE
  • Pinball Freak
« Reply #680 on: August 02, 2023, 11:43:53 am »
FWIW, I received my FeelElec FY6900-60M and its cables from Amazon at a bargain price (119 € delivered)
Not opened yet, but it boots up and links immediatly to the PC.
Here were the steps I took:
- PC Software downloaded from Feeltech website (see replies above to find the link).
- RUN IT AS ADMINISTRATOR on Win11 !   Do NOT connect the FY6900 to the PC yet.
- PC SW is version 6.3.  It's rather buggy.....    Go to Help -> Update -> OK and update to 6.5
- Run version PC SW 6.5 as admnistrator
- Only then, connect the FY6900 to the PC  --->  It connects without any problem
- Firmware version is 1.5.3, I do not know if a newer version exists and where to get it
I will make some basic tests (see if both outputs and inputs are working correctly)
Three small modifications I will also do immediatly:
- Solve the PE wire issue
- Add a 12V fan
- Put a heatsink on the LDO's and maybe the FPGA
« Last Edit: January 03, 2024, 05:23:09 pm by PinheadBE »
Please keep our planet clean
Offline PinheadBE
  • Pinball Freak
« Reply #681 on: August 02, 2023, 11:52:56 pm »
One question about the PSU and the PE issue:
In my house (which dates back to the '70s), there is no PE in my lab.   And I do not use an isolation transfo either.
Is there a risk of frying my equipment (say my 'scope) if I connect it directly to the FY6900 ?  :-BROKE
If so, what are your recommandations (given that installing a PE line would be a LOT of work including breaking walls on two levels, which I'd rather like to avoid....) ?
Offline PinheadBE
  • Pinball Freak
« Reply #682 on: August 04, 2023, 01:44:09 pm »
I've finished to read the complete thread (very difficult to sort things out because of a lot of off-topic, - but very interesting anyway - posts).
To get rid of the isolation problems and HF SMPS induced noise, I intend to replace the 5 V PSU with a simple linear one.
And a good fan, of course....
What power do I have to foresee ?
Does anyone have measured the current drawn on the 5 V line ?
« Last Edit: August 04, 2023, 05:54:05 pm by PinheadBE »
Offline DaneLaw
« Reply #683 on: August 04, 2023, 06:47:11 pm »
As mentioned above my FY6900 seems to rely on 5volt from its PSU board, as can be seen in #678 above' with 5V and G,G, lines.
If all FY6900 revisions is like that and dont dig into +/- 12v lines from their PSU boards, I cant say, as its been rebadge under tons of names, and only got the one above that is around 3 to 4 years old.
- been running my unit from my Micsig scopes 5V USB2 socket, and havent notice any issues, even though that socket cant supply a lot of current.
from the pictures in #678 post and what the powerbanks display reads, it seems to consume around 2.1W in just idle, though havent checked what it peaks at, at various setup & waveforms.
« Last Edit: August 04, 2023, 06:49:05 pm by DaneLaw »
Offline PinheadBE
  • Pinball Freak
« Reply #684 on: August 04, 2023, 06:58:41 pm »
I assume (Worst case scenario) that if the output of a signal 20 Vpp is put into a 50  \$\Omega\$ load, this will draw 0.4 A.   Two outputs => 0.8 A
If I aim for a 5 V - 2 A, it should suffice....  that is my initial guess.
However, my motivation to replace the PSU with a linear one is mainly a noise concern.
I have seen designs based on the venerable LM723 that deliver 0.5 mVpp of noise....
Compared to even a good MeanWell that at least outputs 20 mVpp....
Strangely, that argument (of noise) has not been greatly debated....
Any ideas or experiments on that subject ?
Offline Mm
« Reply #685 on: October 26, 2023, 03:43:16 pm »
My FY6900 (60M) broken after very few minutes of use.
Channel 1 is conpletely dead. Channel 2 has some life to it, but sine wave is not complete and after 6V amplitude it dies too.
Anyone else had similar problems? Is there anything I can do to fix this?
Offline Mm
« Reply #686 on: October 26, 2023, 05:42:29 pm »
I realized that bending little bit the whole case fixes the channel 2. I know it sound crazy but it is true. I have opened the case and if waveform is nonsense on channel 2, then I just press down the bottom of the case (next to the board) and channel 2 gets fixed. Loose connection somewhere?
Offline Mm
« Reply #687 on: October 26, 2023, 06:41:48 pm »
Further investigation got me to realize that this part was very loose (barely attached at all). I was touching it very gently with my finger just to check everything is in place and this part came loose. Im not sure what part is this or is it any way related to the misbehaviour of my device. Can anyone identify what is this and what is the function of it? Im talking about this screw head looking part.
Offline mawyatt
« Reply #688 on: October 26, 2023, 06:53:38 pm »
SMD Potentiometer. What broke off is the wiper. Should be an easy repair (replace with another pot of same resistance value).
BTW looks as if it's been replaced before due to the excess solder flux around the pot.
Best,
« Last Edit: October 26, 2023, 06:55:59 pm by mawyatt »
~Wyatt Labs by Mike~
Offline Mm
« Reply #689 on: October 26, 2023, 07:12:20 pm »
Best,
Thx mate. Can this one buggy SMD potentiometer explain channel 1 being conpletely dead and weird behaviour on channel 2?
Edit:
According to this video, the broken pot should affect only to channel 2.
So, something else must also be broken.
« Last Edit: October 26, 2023, 07:23:43 pm by Mm »
Offline alonsojar
« Reply #690 on: December 15, 2023, 01:06:21 pm »
I have a FY6900-60M purchased 2 years ago.
I read here that current fw is 1.5.3. Mine has 1.4, and the oficial and ugly app (Vers 6.5) shows that latest version is 1.3  while installed version is 1.4, crazy  :--
My board is V2.1 (5V only). The FG works well for me, no issues, so no real need to update it.
Is it possible to update the device or is something depending on the board hw level and cannot be upgraded?
Any clue? Thanks in advance!!
J. Alonso
Offline Adrian_Arg.
  • Country: ar
« Reply #691 on: December 15, 2023, 08:15:03 pm »
There is a version of the software that was brought to update the software and firmware, but as expected, these Chinese ones from the FY6900, not useless ones, so it never worked, so forget about it if you expect help from the manufacturers.
in spanish
hay una version del softwareque trajo para actualizar el soft y el firmware, pero como es de esperar estos chinos los del FY6900, no unos inutiles, entonces nunca funciono, asi que olvidate si esperas de los fabricantes una ayuda.
The following users thanked this post: alonsojar
Offline RUS
« Reply #692 on: February 19, 2024, 09:24:10 am »
Has anyone tested a new software V7.8   for  PC? When trying to update firmware it gives a mistake.
Offline Atlan
  • Country: sk
« Reply #693 on: February 19, 2024, 11:22:07 am »
There is only the 6.5 version on the official website
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Offline RUS
« Reply #694 on: February 19, 2024, 03:12:21 pm »
On the official site Feeltech release of 2024/01/28  " FeelElec Waveform Generator PC software" Download
The following users thanked this post: biastee
Offline Atlan
  • Country: sk
« Reply #695 on: February 19, 2024, 07:11:32 pm »
Yes, I already noticed, but first I logically downloaded the package directly from the given device and there is 6.5. all in all, they have some mess in it.
It says that it cannot connect to the Internet
Offline Bravo
  • This won't take long .............................
« Reply #696 on: February 23, 2024, 12:11:40 am »
Only if you turn off Norton antivirus.
Offline Bravo
« Reply #697 on: February 23, 2024, 11:06:05 am »
I have sent you 2 emails asking about your PC software to control this unit which does not control the frequency. No one has answered. I eventually obtained the latest software which worked (which you only do if you turn off your antivirus). I monitored the TTL output with a scope with serial  decode to find the difference between you old PC program & the new one. Unfortunately your instructions do not show the change.  A disappointing waste of time. You can't complain about the service because there isn't any !!!!! If I had not already spent a lot of time on my control program, I probably would have moved to Juntek.
Offline Adrian_Arg.
  • Country: ar
« Reply #698 on: February 23, 2024, 05:17:11 pm »
hello. For me, the latest version of the software v7.8 does not work, the Windows control tab does not work, whatever option I choose does not work, the other tabs do work, there is no new firmware for the FY6900 either, I am left at 1.3
Offline GigaJoe
« Reply #699 on: April 15, 2024, 05:34:56 pm »
Im on board with it ...
arrived today ....
board version V3.2 ,   different chip
firmware state as 1.5.5.2
https://i.ibb.co/3mz8dfC/01.webp
https://i.ibb.co/MpbS4zR/02.webp
https://i.ibb.co/zGWX2cR/03.webp
Power supply different ,   bigger board , seems better
Wil check everything
« Last Edit: April 15, 2024, 06:49:29 pm by GigaJoe »
