Hello Mr G0HZU,
Can I ask you to give me a hand with my DSO8064A? When I got it someone had wiped the disk, I found an image and have XP and the scope application running but there is no license file and so none of the options it should have are working.
My scope also doesn't have license codes on the back but I also got two very bad copies of the invoices which lists the product codes of the options the original owner bought for this scope (unfortunately I didn't get the license
certificates with the keys):
- N547A-640 128Mpts on 2ch/64Mpts on 4ch
- N5415A InfiniiScan
- E2681A EZJIT
- N5391A Low-speed Serial Data
- N5384A High-speed Serial Data
- N5402A Automotive Serial Data
- E2625A Communications Mask Test Kit
- N5392A Ethernet
- N5416A USB 2.0
- U1882A-001 Power measurement for Infiniium oscilloscopes
- N5430A User-defined function
- E2682A Voice Control
There's another invoice which lists this:
89601A VSA software for Infiniium
89601A-200 Basic Software
89601A-300 Hardware Connectivity
89601A-AYA Flexible Modulation Analysis
89601A-BHB MB-ODFM
They spent nearly $45'000 on these options alone!!! Insane!!
Anyways, I'd really like to get some (all?) of the options back.
Can you help me Mr G0HZU please?
