Author Topic: Hissing crackling noise from my Siglent SDM3035  (Read 7591 times)
Offline robomanTopic starter
« on: March 08, 2024, 11:43:49 pm »
Hello Guys,
I just got my brand new SDM3055 delivered, I was so excited I set it up and hooked to my SIGLENT SPD3303X-E and started taking some DC voltage measurements.
I swear sometimes I hear a hissing, sometimes a crackling noise (like sparks) coming from the multimeter, mostly subdued by the fan noise. It is not consistent, happens occasionally.
Is it something I need to be worried about?
I am brand new to a bench multimeter, so do not know what to expect.
Thanks for your answer.
Offline DimitriP
Re: Hissing crackling noise from my Siglent SDM3035
« Reply #1 on: March 08, 2024, 11:59:58 pm »
Sparking and/or hissing sounds spell RMA :)
 :popcorn:
The following users thanked this post: roboman
« Reply #2 on: March 09, 2024, 12:30:43 am »
How can be sure? The fan noise is overwhelming.
Offline KungFuJosh
  • TEAS is real.
« Reply #3 on: March 09, 2024, 02:34:29 am »
I have an SDM3055, and while the fan is loud, I've never heard ANYTHING besides the fan and relays clicking coming from the DMM.
If you confirm the noise is actually from the DMM, have it replaced.
Offline Veteran68
« Reply #4 on: March 09, 2024, 04:44:16 am »
Are you sure that what you're hearing isn't the relays clicking?
Offline tautech
« Reply #5 on: March 09, 2024, 04:49:26 am »
Check the fan for some foreign matter on/near the grille making intermittent contact with the blades.
Remove with tweezers if/as necessary.
« Reply #6 on: March 09, 2024, 03:32:26 pm »
I hear the relays clicking too, it is clear when I transition to a higher voltage input. Interestingly, the crackling noise is no longer frequent. The meter is just one day old. Let me keep it under observation or put a recording device next to it.
« Last Edit: March 09, 2024, 03:34:21 pm by roboman »
Online 2N3055
  • Country: hr
« Reply #7 on: March 09, 2024, 04:13:29 pm »
Try different power cable.
