Author Topic: CombiScope PM3384  (Read 4627 times)
Offline david69Topic starter
CombiScope PM3384
« on: June 14, 2014, 12:40:35 pm »
Hi, I would like to repair this fault on PM3384 scope,
when I switch them in digital mode, chanel 1 and 3 are out of range, beam is outside display, where I should look into? Thanks for any idea, David
Offline HighVoltage
Re: CombiScope PM3384
« Reply #1 on: June 14, 2014, 04:33:44 pm »
This is a typical problem on the Philips / FLUKE PM33xx Series of these scopes including the "A" and the "B" versions.
I have several of the PM3394B with all options and this problem even happened to those high end scopes.
On your 4 Channel version, it either happens to Channel 1+3 or 2+4 or all off them.
There are two hybrid chips responsible for this problem, one of them is for Channel 1-3 and the other for Channel 2-4
They are a pain to exchange, because they are soldered on to the PCB
The Problem is, that nobody has these hybrid chips anymore.
I have the full schematics and service manuals for these scopes, if you need them.
« Reply #2 on: June 14, 2014, 05:36:17 pm »
I see two hybrids on main processor board. I have opened
signal board with amplifiers, but now I don`t have focused track and text :-( I think that is not easy to soldered this hybrids :-( The focus pot beeps without any
changes on screen... The nice evening David
« Reply #3 on: July 07, 2014, 09:02:05 am »
Hybrids are OK, I changed them in position. Calibration for
chanel 1-3 writes "calibration error 102" which I don`t know :( How continue??
« Reply #4 on: July 08, 2014, 08:14:52 am »
hybrid has  in bad position  pin1 -2,5VDC, pin2 0V, pin3 -2,5VDC,  and in good positon has pin1 -0,5VDC pin2 -0,5VDC and pin3 -0,5VDC ... I change hybrids in position
and it has same parameters :(
The sources 4,5V -6,5V, 17,5V are in both positions...
« Reply #5 on: July 10, 2014, 01:05:43 pm »
first I will change BF579 in oscillator, and look at clock signals again...
« Reply #6 on: July 11, 2014, 12:41:05 pm »
the part of MASPU-A which sources buffer with clock,
is broken :-( PIN61 ClockA is destroyed ...
It needs replace older IC OQ0233WP ....
