This is a relatively cheap and average spec 4.5 digit bench DMM but it has three important things for me: a dual VFD display that I can actually see in my miserable little corner bench, a cal cert and USB data logging support. I picked it up for £320 from Amazon after losing way too many Fluke 45 auctions. Figured I'd just buy a new one, but you can't get them and I can't afford a decent Keysight or Fluke bench meter new!
Notable good things:
1. Fast read speed
2. Input protection that isn't shit. Nice to see a decent quality HRC fuse and PTC in something from China.
3. Dual display (current/voltage, voltage/frequency etc).
4. VFD
5. Nice and easy to use UI.
6. Handle folds flush underneath it, not on top like some other kit.
7. Feels pretty solid.
8. No fan!
9. AC bandwidth is flat to 180KHz which is way more than the quoted 100KHz total bandwidth.
10. Relatively low burden
11. Switchable impedance on low voltage range.
CAT II rated and actually looks like it is.
Notable bad things:
1. The probes that come with it are crap! Chucked and replaced with some Pomona ones.
2. No Kelvin / 4-wire resistance measurement (I don't need this anyway really)
3. You have to manual range to use the 12A range. This confused the shit out of me for about 20 minutes.
4. Crap electrolytic capacitors. I've added a calendar entry to replace these in about 5 years
Design notes:
1. Lots of AD analogue switches and relays
2. Couldn't find the ADC, not that I was particularly looking for that.
3. Brains are in an Altera IC. Assume this is an FPGA, possibly with embedded core of some description.
4. It has a JTAG port by the looks.
5. USB controller is an SiLabs one. Will reverse engineer that from a host machine at some point.
6. Nice design - you can access both sides of the board once you've slid it out of the chassis.
Pictures:
Input!
Whole thing
Analogue switching
Power supply
Front
Quite happy with this
