Author Topic: Quick Question: Fluke 8600A - (S)N7447B BCD Driver (65 °C) temps okay?  (Read 200 times)
Offline kblueTopic starter
Greetings once again!
I repaired a Fluke 8600A and its running fine again within specs. But i'm not sure about the temps of the BCD-Driver marked with N7447B. For Ti SN7447A Ta is specified around 0 - 70 °C. The IC in question settles around 65 °C (23 °C ambient) outside the instrument, is this "okayish"? Mayhaps it's better to fit a flat heatsink onto it for more surface area?
5 V supply seems okay (4,9995 V).
Thanks in advance!
/update 06/05/2024: a little heatsink reduced the temps around 10-15 °C
« Last Edit: June 05, 2024, 09:00:45 pm by kblue »
