Author Topic: MSO5000 FFT question  (Read 1351 times)
Offline SharpTopic starter
« on: December 11, 2021, 07:47:56 pm »
Hi guys
I have a MSO5000 and are now looking into the FFT functionality and have a question for your guys.
If you take a look at the attached MSO5000 screen dumps, I use a 10kHz sine wave 1 volt PP on the FFT 1 screen dump and a 10kHz triangular wave 1 volt PP on the FFT 2.
The FFT setup is dBV and the waveform generator and the MSO is 50 ohm terminated.
My question is on the FFT 1 screen dump – the 1 volt sine wave – The FFT analysis shows the first fundamental to -9.5 dBV – If I want to find the voltage from the FFT analysis I get:  Voltage = 10^(-9.5/20)  = 335mV  - why is it not 1 Volt – what is wrong here ???
Offline mawyatt
Re: MSO5000 FFT question
« Reply #1 on: December 11, 2021, 08:20:54 pm »
Likely because 1Vpp is 0.3536Vrms for a sine wave.
Best
~Wyatt Labs by Mike~
The following users thanked this post: Sharp, Wallace Gasiewicz
« Reply #2 on: December 11, 2021, 09:13:11 pm »
 |O Of cause I’m stupid
@mawyatt  Thank you  ^-^
Offline Wallace Gasiewicz
« Reply #3 on: December 12, 2021, 12:43:46 am »
Me Too!
