Author Topic: Tek VM6000  (Read 1504 times)
Offline langlvTopic starter
Tek VM6000
« on: March 08, 2021, 11:53:46 am »
Hi all,
I'm lucky to buy a Tek VM6000 (1GHz). Just peel off the 1st sticker and it's now a DPO7254. May be with some firmware metamorphosis, it will change to DPO7354. :)
Lang
The following users thanked this post: ddrl46
Offline d37duck
Re: Tek VM6000
« Reply #1 on: April 02, 2021, 04:40:01 pm »
Congratulations on your luck.  I looked for a service manual for your scope and can't fine one, so I have a question.  Have you looked inside to see your VM6000 to see if it is made from DPO7000 parts?
The Tektronix Service manual for DPO7000 (part number 077-0076-03) is available from their website and identified parts. The PC mother board should be an Intel D945 or Advantech AIMB-562.  The Interface PCB is Part Number 671-5912-02 (the -02 part might very).   The Acquisition PCB for DPO7104 and DPO7054 is 672-6166-54, for DPO7254 it's 672-5819-54, and for DPO7354 it's 672-6172-50.
What is inside a VM6000?
Thanks,
Re: Tek VM6000
« Reply #2 on: April 13, 2021, 09:26:44 am »
Hi d37duck,
I opened the VM6000 few months ago to upgrade the CPU. It is based on a Intel D945 mobo which accepts up to Pentium dual core, not Core 2 Duo. I did not remember the part number of others boards. Normally a VM6000 is based on the DPO7104, but this one is truly a DPO7254 with 40 GS/s on single channel. The front sticker is VM6000-1GS/s, and the rear sticker is DPO7254. There is no probe with it, but an adaptor for testing video items.
I am confident that the DPO7354 is "simply" a DPO7254 with hidden license key (or model_ID). According to the manual, even the DPO7354 supports only 2.5GHz analog bandwidth, and use DSP tweaking for achieve the 3.5GHz limit.
best.
« Last Edit: April 13, 2021, 09:28:31 am by langlv »
Offline sprit
  • Country: vn
Re: Tek VM6000
« Reply #3 on: October 27, 2024, 05:34:40 pm »
Hi langlv, hope you have a nice day
I just bid on a VM6000 kit from Ebay, Unfortunately the seller removed the hard drives from both. The TDS7254B I currently have is still able to use the firmware from the official website. But this model is not, I can not find any any info about it. can i ask can you share its program file? Thank you very much.
Sincerely, Jing Feng
