Small status update: I am now receiving Data on Windows, and is almost done with the decoder of the received data!
There is a bit of work to do with the data that i am receiving, example making it faster than it is currently which will be done at some point because it takes too long to sample a voltage, a goal is to be able to samples in less than 1 second
