For the appx 900 bucks you want to spend for, there is IMHO no alternative to the rigol I´ve owned over a year.
The strengths lies in the features the 5000 got for it´s money.
9" touchscreen, hdmi output, 2 channel awg, 100Mpts memory, 8Gsa/s...this is a lot for the money.
On the first sight and also on the second, when you couldn´t spend more.
The pros of this scope:
- Lots of features for the money
- 8GSa/s is still unbeaten in this priceclass - And above
- Lots of mathfunctions, including digital filters
- 2-channel awg up to 25Mhz
- Hardware itself is powerful
- Lots of triggerfunctions
- Even with the 70Mhz entry model you get 350Mhz probes
The cons of this scope are(my opinion):
- Relative slow touchscreen response
- Partly confusing UI in general/"comic style"
- Still having some remarkable bugs in the software, after over 3yrs on the market
- Support/firmware update policy are weak
- Frontend is too noisy for low voltage level measurement - This could be important for your purpose of measuring the voltage of a shunt resistor
If these con-points are not too important for you, you´ll get a scope with very good pricevalue.
But if you can spend more/ save a little time your money until you can afford it, I´ll recommend the scope I got today, the siglent sds2k+.
The pros:
- 10" screen, brighter and clearer than the rigol
- Fast response touchscreen
- Clearer UI, "professional style" looks like the one from lecroy scopes, very good to handle, free choosable channel-colours
- Integrated 50ohm terminations
- Math with freestyle formular editor
- Software in general is more mature in comparison, firmware updates always got not only bugfixes, also feature enhancement
- Very low noise frontend in comparison
- 10bit mode (software, but works really good)
- "Easier" to hack, hack remains after firmware update
The cons:
- No dedicated video output
- 2GSa/s instead of 8 GSa/s
- One channel awg with very rudimental features
- 2 Mathchannels instead of 4 the rigol got
- Logic probes are expensive
- The probes of the 100Mhz model are cheap ones
The cons doesn´t worry much - for me.
For it´s money, it´s the best you can get - like the rigol in it´s priceclass
The SDS2104X, hackable to 500Mhz, cost appx 1400€ incl. VAT.
Working with pro scopes on work, for me it´s the best affordable scope in the range up to 3000€.
When you couldn´t spend more than 900 bucks, get the rigol mso 5074.
Martin
