check out ebay for the kp182 200Watt and kp184 400Watt
looks cheap and apealing ?
anyone of you got one ? can reveal the resolution of load ?
how small and hos accurate can you dial in a load current ?
drift issues ? over heating issues ?
is it silent if load is low ?
tested the serial output available on the kp184 model ?
how does it look on a terminal ?
other things you can say about features ?
constant current, constant resistance ? constant watt ? what can it do ?
