Author Topic: Need a new soldering station :) - JBC vs Hakko  (Read 23594 times)
JuanPC
  • Guest
Re: Need a new soldering station :) - JBC vs Hakko
« Reply #25 on: August 17, 2013, 03:23:51 am »
the LCD doesn't accurately reflect tip temperature in either case.
I have a Baku or Bakku 702B, amazing!
but when i purchased OEM ACME Brand Tips, the temperature was very different because the feedback resistor is 12ohms in the original, but the ACME Brand is different, a few ohms can make a big difference.
Offline roli_bark
« Reply #26 on: August 17, 2013, 06:16:38 am »
Mine does not stay at 180 it cools all the way down. I know this because I pulled the tips off manually. (plus it has a read out for the temperature)
All I'm saying is that when you compare two Irons for re-heating time, you should be fair & compare Apples-to-Apples, and take into account each starting Sleep mode T.
Is your Hakko starting Sleep T 24c ? 100c ? 180c ?
What Sleep T is your JBS configured to ?
These kind of things.
« Last Edit: August 17, 2013, 06:55:20 am by roli_bark »
Offline nanofrog
« Reply #27 on: February 21, 2017, 04:26:10 pm »
You'd do better to start a new thread.  ;)
