V2.26 is up
It includes some additions to TestController and a few new devices.
Added: Grid Panel item to control a power supply with a couple of fixed settings.
Added: Grid Panel item to control a two power supplies with a couple of fixed settings.
Added: Grid Panel item to control one or more loads with a couple of fixed settings. This will automatic distribute the load between them.
Added: Marconi 2955 Radio Communications Test Set (Thanks rachdatu)
Added: Owon XDM3051 DMM (Thanks DiplIngenieur)
Added: Owon P4603, Owon P4305 power supplies (Thanks DiplIngenieur)
Added: Support for #scpiCmd that uses calculator scripts
Added: control set, like multi, but can handle more parameters
Added: :labelformat: Some text formatting on the "Setup" popups.
Changed: RTC1002, HMC8012, NGE100 (Thanks PL)
Some of the addition makes more advanced device definitions possible:
The control set is similar to control multi, but instead combines regular controls (Including multi):
![](https://lygte-info.dk/pic/Projects/TestController/Controls/set.png)
If is possible in #scpiCmd to use regular scripts, this is only for very special cases.
Some of the text on the setup popup can be adjusted with colors, font and style, again something that is recommended to use sparingly.
For the grid panel it is now possible to create simple controls to set a preset power supply:
![](https://lygte-info.dk/pic/Projects/TestController/DocGridPanel/SetDualPSVoltCurrentWithOff.png)
This is also possible for a load or a couple of loads:
![](https://lygte-info.dk/pic/Projects/TestController/DocGridPanel/SetMultiLoadsWithOff.png)
This makes it easy to use a couple of loads together for higher current/power.
