Author Topic: Program that can log from many multimeters.  (Read 626264 times)
Kirkhaan and 10 Guests are viewing this topic.
Offline vladobac
  • Country: sk
« Reply #2500 on: June 11, 2022, 07:14:49 pm »
I bought an electronic load Atorch DL24M-H.
DL24M-H is not listed in the "ATorchPX100Devices.txt" device file.
Maybe you can ad the DL24M-H metadef?
If you could advise me where to assign a new device name, I would be very grateful. I will make the change at my own risk. Well thank you.
Offline HKJTopic starter
    • Tests
« Reply #2501 on: June 11, 2022, 07:22:11 pm »
You add a new #metadef statement, usually you will copy a already existing one and then modify the parameters to match you new device.
When you have tested that it works, you can attach it to a post in this thread and I will update the definition file. Posting only the #meatadef and the name of the file it goes into or the full file is up to your, I can use either.
The most important parameter in a #metadef is the #name statement, it is the name you can find on the "Load devices" page. Of course the other definitions are supposed to match the name!
Offline vladobac
  • Country: sk
« Reply #2502 on: June 11, 2022, 10:14:46 pm »
I added blue colored text to the file "ATorchPX100Devices", the device appeared in the menu, but the connection does not work ...
I guess it's beyond my power. Thank you for all the help
Offline vladobac
  • Country: sk
« Reply #2503 on: June 12, 2022, 06:18:20 am »
I paired the new DL24M-H device on COM7 and the old DL24 on COM8. Only the old device was connected via DL24, DL24P and PX100. I also tried to connect with the program "Battery Tester PX100" and the results were the same.
    • Tests
« Reply #2504 on: June 12, 2022, 06:35:02 am »
It looks like it may have changed protocol. You can try running TestController in debug mode and see if there are any data.
    • Tests
« Reply #2505 on: June 12, 2022, 06:59:29 am »
V2.07 is up
There are many improvements to the Block driver, math support for PTC and a few new devices.
   Added: Function makeDouble() for assembling a number from multiple elements, mostly for Block driver.
   Added: Block driver support for CRC or checksum
   Added: Block driver support for streaming data
   Added: Function vdivLowR(Vin,highR,vout) as a easy way to measure in-circuit sensors with a pullup resistor.
   Added: PTC sensor math for Vishay TFPT sensors: ptc(type,resistance) ptcT(type,temperature)
   Added: PTC sensor math for NXP and Infineon KTY sensors: ptc(type,resistance) ptcT(type,temperature)
   Added: GW Instek ASR-2050, GW Instek ASR-2100, GW Instek ASR-3200, GW Instek ASR-3300, GW Instek ASR-3400 Mains supplies (Thanks gby)
   Added: ParamSweeper can include the sweeping parameters in the logging.
   Added: HP 6624A quad power supply (Thanks Chernobyl)
   Added: ascii and hex number format to Block driver.
   Added: In math fields using INS or right-click will give a list of channel variables.
   Fixed: Annotations did not work on sync'ed scales.
I got requests for improvements from two different sources and they both involved the Block driver.
Some functions have been added to support some precision PTC resistors httpe:///lygte-info.dk/project/TestControllerFunctions%20UK.html#Temperature_sensors_PTC
When writing math formulas a shortcut for the connected device values has been added (INS key or right click). It works most places where expressions can be used.
ParamSweeper can sweep any adjustable parameter for a device, but not all of them are included in logging, now they can be by checking a box.
Offline vladobac
  • Country: sk
« Reply #2506 on: June 12, 2022, 07:37:06 am »
First I have to study how TC starts in debug mode ... When I can do that I will publish the results. Well thank you. :)
    • Tests
« Reply #2507 on: June 12, 2022, 07:43:02 am »
You start it with the "testControllerDebug.bat" file (At least on Windows).
The following users thanked this post: vladobac
Offline vladobac
  • Country: sk
« Reply #2508 on: June 12, 2022, 08:15:17 am »
I moved to a desktop PC. I connected to COM5 and ran the debug.
    • Tests
« Reply #2509 on: June 12, 2022, 08:31:06 am »
Try downloading http://lygte-info.dk/pic/Projects/TestController/TestController.jar and replace your current .jar file with it.
Offline vladobac
  • Country: sk
« Reply #2510 on: June 12, 2022, 09:15:59 am »
Great! I have connected, but I do not have voltage, current values ​​... But it is possible to switch the load on and off, set the end voltage, set the test time and reset the values. The current setting does not work properly. Sets about 4x smaller value. I set 5A, the fact is 1,280A. You are very handy.
Offline vladobac
  • Country: sk
« Reply #2511 on: June 12, 2022, 09:19:26 am »
Sorry my Google Translator English
« Last Edit: June 13, 2022, 05:44:23 am by vladobac »
    • Tests
« Reply #2512 on: June 12, 2022, 10:16:07 am »
You can fix the current by adjusting this line:
#scpiCmd setCurrent tx 2 (value) *dd
I.e. use (value*4) instead of (value)
For current & voltage check the logged values. You can use "voltage?" and "current?" on the command line to only check that value and isolate the log for that.
Offline vladobac
  • Country: sk
« Reply #2513 on: June 12, 2022, 10:40:56 am »
"For current & voltage check the logged values. You can use "voltage?" and "current?" on the command line to only check that value and isolate the log for that."
I'm not a programmer. I don't understand what to do ...
    • Tests
« Reply #2514 on: June 12, 2022, 11:59:32 am »
Start in debug mode as before, then type the command and press enter:
Offline vladobac
  • Country: sk
« Reply #2515 on: June 12, 2022, 12:17:18 pm »
OK
Offline vladobac
  • Country: sk
« Reply #2516 on: June 12, 2022, 12:23:54 pm »
Next
    • Tests
« Reply #2517 on: June 12, 2022, 12:44:27 pm »
Next
Update .jar file with http://lygte-info.dk/pic/Projects/TestController/TestController.jar and try again.
Note: It may take up to an hour before you can download the new version (V2.10), please check About on the configuration page to be sure you have the updated version.
Offline vladobac
  • Country: sk
« Reply #2518 on: June 12, 2022, 01:49:38 pm »
It's not working yet.
I have a Li-Ion battery connected to the load, so it should show about 4.1V
Offline vladobac
  • Country: sk
« Reply #2519 on: June 12, 2022, 02:27:31 pm »
Even if I start the load and the current starts to flow, V, A, Ah and Wh in the TestController have zero values.
« Last Edit: June 13, 2022, 05:21:08 am by vladobac »
Offline rachdatu
« Reply #2520 on: June 12, 2022, 02:41:05 pm »
There is no easy way to make a CRC. What driver do you use? Maybe I can add it to the driver, another option is a function to calculate crc.
This is the block driver.
In next version you can change you "s" specified to "h" and get the hex converted to integers.
There will also be a optional crc/checksum calculation you can activate.
"s" to "h" works. Now I get decimals. Fantastic  :-+
CRC: Thanks for adding that function.  I have tried to get a CRC using the linked website (https://crccalc.com/)
Could not get my expected value (020A) .
000A8A0000020A
Do I have to enter the control chars ? (start with 0x0c and end with 0x0d)
Offline vladobac
  • Country: sk
« Reply #2521 on: June 12, 2022, 02:52:51 pm »
Next
I am attaching a .csv record in TC before the upgrade. I tested a 36V (540Wh) e-bike battery in CC 10A mode.
There were two strange voltage drops, and the current record was very often lost chaotically. The minutes of Ah and Wh looked fine. Therefore, I upgraded the firmware in good faith and since then I have exchanged minor problems for larger ... |O
https://drive.google.com/file/d/1KjilKsELQXsZtNIhEvNf60o9-PBMVZmY/view?usp=sharing
    • Tests
« Reply #2522 on: June 12, 2022, 03:27:22 pm »
Please post a log with the "voltage?" command and that 4.1V battery.
    • Tests
« Reply #2523 on: June 12, 2022, 03:29:12 pm »
Sort of, the protocol has changed. I hope we can fix it together, i.e. I make modifications and you test.
    • Tests
« Reply #2524 on: June 12, 2022, 03:40:45 pm »
000A8A0000020A
I cannot say what exactly you need to do. The idea is you put a original message without  the CRC into the crccalc website and then find the needed CRC parameters (poly, init, ref, xor). This will be the line where the shown CRC matches the CRC from the original message, note that high/low byte in the CRC can be swapped.
It may be a good idea to checkmark "Show processed data (HEX)", then you know exactly what the calculated CRC covers.
You can then add a #checksum statement to your definition with the parameters.
