V2.04 is up
It adds some new definitions and a few new functions.
Fixed: GridPanel, device popups. There was a null pointer error.
Added: Definition DMM subdriver to USBHIDDMM driver
Changed: jSerialComm updated to V2.91
Added: Keysight U1213A multimeter (Thanks WS)
Added: Keysight U1241C multimeter (Thanks WS)
Fixed: Rigol DM30xx, Riden RD 6006, Siglent, Rigol DL30x1x (Thanks WS)
Added: Rigol DL3021, Rigol DL3021A, Rigol DL3031, Rigol DL3031A electronic load(Thanks WS)
Added: R&S HMP2020 Power supply (Thanks WS)
Added: GridPanel Adjust and Dual adjust, these are analog like controls to adjust any parameter on a device with the mouse.
Added: R&S NGE102 & NGE102B power supplies (Thanks PL)
Added: R&S HMC8012 bench multimeter (Thanks PL)
Added: Log event as script. The script will work similar to the popup, but is not exactly the same.
Added: Timeout setting and handling for devices, see Configuration page.
Added: Tooltips to the popups menu and a few other places.
Added tool tips to the "popups" list, it was long overdue!
Log event as script will convert the Log Event popup to a script, this can be used as a start for custom scripts.
One idea is to generate two scripts: One for charging a battery, one for discharging a battery, then manually combine them into a single script that can charge and discharge a battery.
New configuration to handle timeouts.
"Analog" adjustment of device parameter in GridPanel, use mouse wheel or drag on the star.
