There is an error in the RidenRD60xx file.
It is not possible to set the current to more than 1A. If you choose 1A, then in fact the current is set to 10A.
Yes, that is true.
Look in devicefile RidenRD60xx.txt and replace
This will be fixed in the next release.
I only have definitions for RD6006 & RD6012, if anybody makes definitions for other models I am very interested in getting them.
Note: A definition is probably not more than the 10 lines Pukker has posted, just with other values.
There are also more values where 1000 must be replaced with 100.
Done in the attached RD60xx.txt file.
Only tested with RD6012, the only one I have. Firmware is the latest version from Unisoft, which is great.
Two problems I've seen and I don't know how to solve.
1. in RD6012 popup, tab settings, the Buzzer function was inverted, corrected that, but to select On I have to click Off and vv.
2. in the tab Memory M4 is selected by default and selecting another, (M0 to M9), always returns to M4
Making settings to M4 works OK, but only M4 is selectable. Don't know how to solve.
BTW. Making settings from Testcontroller is not the main function, logging (core business) works fine.
