Hello HKJ. I purchased a new Kunkin KP184 (2021.02.27). When I try to establish a connection, I get a message:
I'm ready to help.
The message do not popup when you try to connect, but when you ask for a "Preview"
When you have selected the KP184 in the combobox, you have to press add, then click on the "Address" field and type in the comport. You may also have to modify the baudrate.
You can now try to "Reload" and if it a new firmware it will fail.
To test with the new firmware:
Open the file "Kunkin KP184.txt"
Change the subdriver line to:
#subDriver Kunkinx
Add a ; before the line: #verifyDevice 1840 model?
This line will have to be fixed later on, but for testing it is easier to disable it.
First try is adding some handshake signals to the baudrate on the load device page (Use the correct baudrate):
9600N81dr
9600N81Dr
9600N81dR
9600N81DR
Press Reconnect to try each setting
