Author Topic: Program that can log from many multimeters.  (Read 612413 times)
0 Members and 17 Guests are viewing this topic.
Offline Bad_Driver
« Reply #1250 on: October 27, 2020, 03:40:05 pm »
Thanks for your advice! I will work on it. I understood the point with the "=>"
B.D.
Online HKJTopic starter
    • Tests
« Reply #1251 on: October 27, 2020, 04:29:42 pm »
I am not sure my advice is correct, it will only work if the => prompt is followed by a newline and prompts are usually not.
I may have to add functions to handle a prompt.
Offline Bad_Driver
« Reply #1252 on: October 28, 2020, 09:19:07 am »
I have done a Hex-Terminal.
The prompt is always finished with 0DH 0AH (CR/LF). So I try your advice during the next days.
Thanks again!
B.D.
Offline dirkwim07
« Reply #1253 on: October 28, 2020, 12:37:34 pm »
@hkj Here's a minute of data https://justpaste.it/9jk97 from the DL24 device during load testing a battery. This was taken with 115200bps. This one is taken with 9600bps  https://justpaste.it/6s5w4
« Last Edit: October 28, 2020, 12:47:48 pm by dirkwim07 »
    • Tests
« Reply #1254 on: October 28, 2020, 01:46:03 pm »
V1.40 is up
This is mostly extension to charting and it only works from scripts.
V1.40
   Added: #removePromptChars to SCPIx driver
   Added: ATorch USB, general support for USB protocol, may later be change to one or more model names
   Added: ATorch AT3010 AC energy meter for panel mounting
   Added: ATorch DL24P DC load
   Changed: Bar drawing on histogram, they will now be plain when more than 100 bins are used.
   Added: Values popup to histogram
   Fixed: Missing header when saving histogram, header will only be used for one histogram, not for two or tree.
   Added: #chartAnnotate add lines, arrows and text to a chart.
   Added: #chartScaleSync makes it possible to share a scale between multiple curves
   Added: #chartBackground customize colors for the different elements in the chart.
   Added: #chartColors customize a new set of curve colors
   Added: #chartScaleName change the displayed scale name on the chart
I used this script to generate the above (From already loaded data):
#chartTitle "Not file name as title"
#chartBackground aquamarine honeydew blue sandybrown red
#chartcurves VRG.Ramp VSG_1.Sine VSG_2.Sine
#chartScaleSync VRG.Ramp VSG_1.Sine VSG_2.Sine
#CHARTCOLORS (255,0,0) (240,120,0) (240,0,120)
#CHARTSCALENAME VRG.Ramp Ramp
#CHARTSCALENAME VSG_1.Sine "Fast sine"
#CHARTSCALENAME VSG_2.Sine "Slow sine"
#chartannotate line 0 0 130 0 blue 1
#chartannotate line 0 7 130 7 yellow 1 "...   "
#chartannotate line 0 -7 130 -7 yellow 1 "...   "
#chartannotate arrow "End of first ramp" 30 0 60 darkolivegreen 2
#chartannotate text "Advanced chart demonstration" lb 2 9  green 2 white
I was asked about a cursor in histogram mode, it is possible now with a value popup:
The Atorch functions is not really tested and according to dirkwim07 I need to change the type of serial port. When I get some more feedback on ATorch I will adjust the definition.
The following users thanked this post: tubularnut, dirkwim07
    • Tests
« Reply #1255 on: October 28, 2020, 06:42:10 pm »
With the SCPIx driver you can now use #removePromptChars
Using "#removePromptChars 4" will remove 4 characters, i.e. it will include CR LF.
And then you do not need to redefine anything and it will probably also work with GPIB.
Offline Bad_Driver
« Reply #1256 on: October 29, 2020, 08:03:29 am »
Hi HKJ
again thanks for the new release and your advices! Yesterday I tested your txrx2 - hint and it works!
But the new functionality "removePromptChars" looks good and I will check it, unfortunately I'm a litte bit short of time these days.
best regards B.D.
Offline dirkwim07
« Reply #1257 on: October 29, 2020, 11:57:46 am »
cool that you've added the Atarch.
here you can see the data https://imgur.com/a/OygmSzl
Voltage and Current readings are fine, but the power and energy are not coming in.
What could I change in order to try to get the right values? And would I be able to change the voltage to 3 decimals and add the Capicity and Timing from the device?
#metaSection DC_DEVICE
#subDriver DC
#value Voltage V D1
#value Current A D3
#value Power W D1
#value Energy Wh D2
#askValues values?
; Format of answer: f=float, u=remove trailing letters, x=skip, *=Zero upper case values if this value is 0
#askValuesReadFormat ffffxxxx
#interfacetype Power
#interface readVoltage 0
#interface readCurrent 1
#interface readPower 2
#interface readEnergy 3
#cmdSetup buttons Reset
:write: tx
Wh 1
Ah 2
Time 3
All 5
#cmdSetup numberInt Backlight
:read: backlightTimer?
:write: tx 0x21
sec 0 255
    • Tests
« Reply #1258 on: October 29, 2020, 12:10:14 pm »
#value Voltage V D1
#value Current A D3
#value Power W D1
#value Energy Wh D2
These lines control available columns and decimals, but there is no point in adding more decimals, the data I receive do not contain them.
This line control what to include, each f is a value and x is a ignored part. If you add more f you must also and more #value lines, they must match.
Try testing until Ah & Wh values are 1 or more and see if anything shows up.
Note: TC can calculate these values and do not really need them.
Offline dirkwim07
« Reply #1259 on: October 29, 2020, 02:24:47 pm »
Ill try :)
two questions. I've posted you hex data, is that something I also could translate to figure out what data it contain? and I editied the atarch txt file but the changes are not applied. Does test-controller store it's settings in register? I already tried removing the program and installing again but no change
    • Tests
« Reply #1260 on: October 29, 2020, 03:18:53 pm »
Yes, somebody posted a link that shows the format: https://github.com/NiceLabs/atorch-console/blob/master/docs/protocol-design.md
Nothing is save in secret locations, but the definitions are only loaded on program start, i.e. you have to restart the program after doing changes.
Note: The Atorch definition is 4 definitions in one file, you have to modify the correct one.
Starting TC in debug mode will give a lot of output, but may help with understanding how it works.
Offline dirkwim07
« Reply #1261 on: October 29, 2020, 06:14:30 pm »
But how does your program translate the hex data FF551103310000000001 to #askValuesReadFormat ffffxffxx
    • Tests
« Reply #1262 on: October 29, 2020, 06:25:00 pm »
The internal driver has a table off offsets, size and division factor for the different elements, using this it will convert the hex string to a couple of numbers.
The #askValuesReadFormat is then used to pick the interesting values.
Offline dirkwim07
« Reply #1263 on: October 29, 2020, 06:43:08 pm »
Sorry for so many questions :) but how could I edit the driver? I've already extracted testcontroller.jar but now the challenge is to find the file. And which program should I need for editing? I have a bit of programlanguage understanding so maybe Im able to edit some
    • Tests
« Reply #1264 on: October 29, 2020, 07:02:40 pm »
You cannot edit the driver, only the definitions.
If the DL24P codes the bytes another way, you just have to post a list and I will add it to the next version of TC
Offline dirkwim07
« Reply #1265 on: October 29, 2020, 07:32:58 pm »
I've checked the data from #metaSection DCLOAD_DEVICE in TestController.
The data which I can show in TC is Voltage, Current, Seconds and Capacity. I've tried al the ffffxxx combinations.
This page https://github.com/NiceLabs/atorch-console/blob/master/docs/protocol-design.md shows the following data.
Could it be that the definitions are a bit off? I don't know which list I should send or how to get it? Hope that it's possible to show data with more decimals.
DC Meter Report
Offset   Field   Block size   Note
03   Device Type   1 byte   01 Device Type
04   Voltage   3 byte   24 bit BE (divide by 10)
07   Amp   3 byte   24 bit BE (divide by 1000)
0A   Watt   3 byte   24 bit BE (divide by 10)
0D   W·h   4 byte   32 bit BE (divide by 100)
11   Price (per kW·h)   3 byte   24 bit BE (divide by 100)
14      4 byte   unknown value
18   Temperature   2 byte   16 bit BE
1A   Hour   2 byte   16 bit BE
1C   Minute   1 byte
1D   Second   1 byte
1E   Backlight   1 byte
    • Tests
« Reply #1266 on: October 29, 2020, 07:39:49 pm »
All the 3 lists are already implemented in TC and selected with the "#subDriver" specification, but if you select a wrong list TC will not accept it (The protocol includes a id code for the list used).
I do not know if the definitions are fully correct, I am a little bit suspicious about the Ah and Wh values. The location is probably correct, but the factors may be wrong.
I believe the DC specifications are for a DC power meter, but here it is reused for a DC load and I wonder if there are some differences.
Offline dirkwim07
« Reply #1267 on: October 29, 2020, 08:07:59 pm »
Mmh, then I think I cant help any further. Can send more hex codes from this device but I think we need information from the maker of the software behind this device
    • Tests
« Reply #1268 on: October 29, 2020, 08:13:10 pm »
Hex codes and a photo of the display when there is above 1Ah & 1Wh on it would be a good help.
Offline gby
« Reply #1269 on: October 29, 2020, 11:47:40 pm »
Hi HKJ,
The Tektronix scope device file I made is not working properly for some of the models (MDO3xxx, DPO3xxx).  Specifically, logging of the 5 measurements ends up as
   Measurement 1:   OK
   Measurement 2:   ends up with measurement 3 number
   Measurement 3:   always 0.0000
   Measurement 4:   always 0
   Measurement 5:   always 0
This device file works fine for multiple other Tektronix scope families and the SCPI documentation for all of them is the same.  To investigate the issue I did some dos window debug traces while connected to a working scope and to a not working one.
;; Found Tektronix MDO3024 TekScope on 192.168.1.46 sn: C021804
;; Found Tektronix DPO3034 TekScope on 192.168.1.181 sn: C013387
;; OscTek_4: Tx <MEASUREMENT:MEAS1:VALUE?>
;; OscTek_87: Tx <MEASUREMENT:MEAS1:VALUE?>
;; OscTek_4: Rx <:MEASUREMENT:MEAS1:VALUE 38.7249E-3>
;; OscTek_4: Tx <MEASUREMENT:MEAS2:VALUE?>
;; OscTek_4: Rx <:MEASUREMENT:MEAS2:VALUE -126.2936>
;; OscTek_4: Tx <MEASUREMENT:MEAS3:VALUE?>
;; OscTek_4: Rx <:MEASUREMENT:MEAS3:VALUE 165.7627>
;; OscTek_4: Tx <MEASUREMENT:MEAS4:VALUE?>
;; OscTek_4: Rx <:MEASUREMENT:MEAS4:VALUE 7.0186E-3>
;; OscTek_4: Tx <MEASURE:IMMED:VALUE?>
;; OscTek_4: Rx <:MEASUREMENT:IMMED:VALUE 5.6271E-3>
;; OscTek_4: Rx as numbers <0.0387249 -126.2936 165.7627 0.0070186 0.0056271>
;; OscTek_87: Rx <1.0204E-3
;; OscTek_87: Tx <MEASUREMENT:MEAS2:VALUE?>
;; OscTek_87: Rx <57.3830
;; OscTek_87: Tx <MEASUREMENT:MEAS3:VALUE?>
;; OscTek_87: Rx <-43.9564
;; OscTek_87: Tx <MEASUREMENT:MEAS4:VALUE?>
;; OscTek_87: Rx <2.0977E-3
;; OscTek_87: Tx <MEASURE:IMMED:VALUE?>
;; OscTek_87: Rx <1.4246E-3
;; OscTek_87: Rx as numbers <57.383 0.0020977>
I note three things about the above:
1.  Working OscTek_4 final log values line has correct 5 numbers while the not working OscTek_87 final log values line only reports two numbers instead of 5.
2.  Not working OscTek_87 individual queries returns all 5 log numbers correctly.  It is just the final collecting of the numbers together step that fails.
3.  Not working OscTek_87 individual queries seems to have an extra CR LF after the number but before the ">" ending delimiter.  No idea if this is a Tektronix or a TestController extra CR LF??
I did a further experiment where I changed the read format line.  The above is the result if the read format line is
   #askValuesReadFormat xFxFxFxFxF
If I change the read format to
   #askValuesReadFormat uFuFuFuFuF
the error switches around.  Now the previously working OscTek_4 does not work and the previously not working OscTek_87 does work.
Do you think there is an error in the "Tektronix MDO MSO DPO TDS.txt" device file or can you think of a simple change to accommodate the difference?
Should I change the device file to use two different #askValuesRead lines depending on scope model number?  If so, then what is the simple way to do this?
Is there a bug in TestController causing the xFxFxFxFxF read string to be assembled wrong for the not working model shown in the debug trace??
    • Tests
« Reply #1270 on: October 30, 2020, 07:30:55 am »
You can rid of the extra CR  LF with some :readmath:
replace(replace(value,"\r",""),"\n","");
A shorter version may be enough:
replace(value,"\r\n","");
What are you doing? x=ignore value, F=parse number, u=parse number with unit after it (like 5V)
Mostly upper and lower case works the same way, only exception is when a * is present in the line.
You can use #sections to select between two different definitions.
Offline dirkwim07
« Reply #1271 on: October 30, 2020, 11:39:42 am »
Hereby a picture and the last minute of the log https://justpaste.it/6g9lj from the dl24p device. If you need a longer log please let me know:)
    • Tests
« Reply #1272 on: October 30, 2020, 01:34:21 pm »
Thanks, I cannot find any W, Ah or Wh data in the message, but I wonder why there is some data after the message.
I have added my own W, Ah and Wh calculations to the driver, this means it will now list:
This will be included from next version.
It looks like time and temperature is included in the message.
« Last Edit: October 30, 2020, 01:36:03 pm by HKJ »
The following users thanked this post: dirkwim07
Offline gby
« Reply #1273 on: October 30, 2020, 01:49:33 pm »
These devices are just SCPI so the logging #askValues command is just:
   #askValues MEASUREMENT:MEAS1:VALUE?;MEASUREMENT:MEAS2:VALUE?;MEASUREMENT:MEAS3:VALUE?;MEASUREMENT:MEAS4:VALUE?;MEASURE:IMMED:VALUE?
Are you saying that it is possible to have :readmath: just after this line to remove the 5 extra "\n" and "\r"?  I don't think that would work since the error happens inside the #askValues in that #askValues just returns two numbers like:
and no further processing would get the missing numbers back to my mind.
I admit the #askValuesReadFormats I am using do not all make sense based on their intended functions/definitions.  I just tried experiments and noted results.  I am guessing that the root cause issue is that different scope families return values in different formats:
   MDO3000 (like OscTek_4 in these tests) returns an echo of command ending in the number which needs read format xfxfxfxfxf to remove command echo
   DPO3023 (like OscTek_87 in these tests) returns just the number with an extra \n \r and works with readformat fffff or ufufufufufuf
I will work on having the device file use different #askValuesReadFormat for different devices.  Thanks for the hints.
    • Tests
« Reply #1274 on: October 30, 2020, 02:04:48 pm »
Yes, except it is not called :readmath: but #askValuesMathFormat
It will get the string before it is converted to numbers.
