With ATorch
I have basically implemented all 3 categories AC, DC & USB
But I need to know if my scaling is correct, the problem is Ah & Wh, they do not match the examples on the post linked earlier, but I uses the divide factor specified. Please post hex dump in ascii format, I have programmed a Arduino where I can simply dump an hex ascii string into and it will transmit it each second. I.e. get soma Ah or Wh readout and post it together with a hex dump, then I can verify.
I need some baudrates, are they fixed at 9600 or something else or are they adjustable?
I ignore temperature, time and price values and I do see any purpose in them (They are decoded, but I do not fill them into any columns).
I also need some device names, just now I have:
ATorch DL24P -> DC
ATorch AT3010 -> AC
ATorch USB -> USB
I would like to have some more model numbers and what category (AC/DC/USB) they are in
