V1.25 A couple of small additions and a bug fix.
Added: Load will accept time in h:m:s format and dateTime in system format.
Added: Tab format with comma as decimal point (ctab).
Added: #Connected? Generated a list of used devices and computer, can be saved to a file.
Added: Help pages got a list of scripting command (A few already had) related to that function/page/popup.
Added: Save button on Command page will now ask for format: log, script or menu
Added: Export to table button in export popup.
Added: #ExportTableReload Export and reload table, this is designed to do data reduction in the table
Added: Export ReduceByFormula, use a expression to select data for export
Fixed: Digital curves on chart (They disappeared due to previous update)
With the additions to the export popup it is very easy to remove some data from the table.
![](http://lygte-info.dk/pic/Projects/TestController/DocExport/ExportReduceByFormula.png)
Remove the negative part of a sinus wave.
![](http://lygte-info.dk/pic/Projects/TestController/DocExport/ExportReduceByFormula2.png)
And use "To Table" to directly send it back into TestController (It is a good idea to save the original data first).
