V1.04 is up
This has a new popup and many small changes:
Added: Definition file for binary DMM protocols
Added: Program icon, image file is included as png and ico
Added: Alarm setting than can make a visual and/or audible alarm when values are out of specified range.
Added: Alarm commands: #SETALARM #ADJUSTALARM #CLOSEALARM
Added: #CLOSEALL that will close all popups.
Fixed: The 3 ways to close all popups (Reconnect, popups/closeAll, #closeAll) now works similar and closes all popups (Calculator & Timer only with #closeall)
Added: Most # commands can now handle expressions, they must be in parenthesis ()
Added: Integers can nearly everywhere be in decimal, hex or binary (Use prefix 0x/0b or postfix h/b)
Added: Brymen BM251s, BM252s, BM255s and BM257s
It is now possible to add basically any DMM with a serial interface using either "Single value" or "Binary DMM protocol", documentation:
http://lygte-info.dk/project/TestControllerConfigDevice2%20UK.htmlI made a program icon, it is not great, but better than the standard Java icon:
![](http://lygte-info.dk/pic/Projects/TestController/CurveIcon.png)
The Brymen BM250s series meters has been added, for the money I believe you get a very good meter with computer interface (Interface is a separate buy).
I added a alarm popup:
![](http://lygte-info.dk/pic/Projects/TestController/DocAlarm/Alarm.png)
The alarm is designed to be attention-grabbing, it can be used to signal when to stop a test (Like a battery discharge test with a resistor). Please do not complain here if somebody throws you computer out the nearest window
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
It can also be configured to be more discrete.
The smaller versions of the alarm window:
![](http://lygte-info.dk/pic/Projects/TestController/DocAlarm/Alarm1.png)
![](http://lygte-info.dk/pic/Projects/TestController/DocAlarm/Alarm2.png)
