V1.00 is up
It is a lot of smaller details:
Added: max/min modes to "Adjust scale", they will update ref to show the highest or lowest values seen
Fixed: Chart search left/right zero/value might pick the entry next to best match.
Added: Find max raise/fall rate on chart, it uses a 0.1% window (Min 4 samples) for calculating slope.
Added: Relative values on chart value popup by placing a zero marker (This will only affect the popup, not scales and search).
Fixed: When slow logging, math channels might be wrong if "Current values" was used at the same time.
Added: AdjustScale supports math channels
Added: Readout supports math channels
Added: #CommandTime? that list how fast devices answer a request for values (Something that reads values must be used first).
Fixed: Did not close failed connection, this could block ports for other programs while TestController is running.
Both Adjust scale and the large digit readout now supports Math channels:
I added relative readouts to the chart, place a zero marker and all values will be relative to it:
It is possible to click on values to switch back to absolute (Removing the zero marker will switch all values to absolute):
The magenta markers show what values are relative, the zero marker on the chart is also magenta.
