>You have start and stop buttons.
Where they are ? I can see Start/Stop in timer , but this actually is not stopping grabing data, e.g in Chart tab
Pause is usefull e.g. if you will pause DUT to bring a cup of tee or you will know that next hour nothing usefull will not happened or no need to capture useless data just waiting for event to restart capturing data.
I think Pause can be scripted as well - I could net find a description for commands other in exaples, but I think with some experiments I can learn myself how to use it, anyway that would be bit wired setup for Pause
>The table/chart will automatic clear when you start a new log.
OK, but I think it will be still usefull, like cleanning chart , but lesving table, or the other way, or both.
>I have never seen this and due to that it is a bit hard to fix.
OK, clear. Java is wired/not very reliable framework. There is something happening with connections , in my setup I have UT61E to grab current and BM869s to temperature. This is requireing to add/remodve/reconnect a few times before they will work at the same time, sometim it will stick to UT61E hard that even if I remove it Current valuse will show UT61E as DC volatege , no matter that UT61E is on AC Amp range. I think that may be something close to Java framework used for communication.
