V0.62 is up.
It includes the 3 Owon PS from gby.
I have change the initialization of the setup menu, now it will show the popup first and then initialize it, it is a fraction of a second slower, but that is more than compensated for by making popup visible much faster.
The above also means I could add a preview of the popups, it is found by right clicking the master device selection combobox.
The preview do not communicate, this means all text field will be empty, radiobuttons will not be selected, etc.. It is possible to play with the popups.
It also means the :visible: tag will be enabled for all lines, this can be seen in the Siglent SDG popups. When using a it while connected to a device the :visible: tag will work as before.
