Author Topic: Program that can log from many multimeters.  (Read 649176 times)
HKJ and 19 Guests are viewing this topic.
Offline MikeLud
« Reply #400 on: April 30, 2020, 01:09:16 pm »
HKJ,
Attached is a device file for the Riden RD6006.
* RidenRD6006.txt (4.59 kB - downloaded 60 times.)
Online HKJTopic starter
    • Tests
« Reply #401 on: April 30, 2020, 01:12:54 pm »
So fast?
The problem was some regex that said [0-9]+, but had to be [0-9.]+, it was very obvious in debug mode (At least for me).
For the SDG1000X, only the frequency limits actually have to be changed ?!? (at least that's how I had done it successfully with the old version).
Please post the changed definition or email it to me.
    • Tests
« Reply #402 on: April 30, 2020, 01:14:39 pm »
Thanks, it will be included in next update.
Offline klausES
  • Restore Sony ES/Esprit era
« Reply #403 on: April 30, 2020, 01:18:51 pm »
Again SDG's ... 2000X to 1000X Series.
If, as far as the operation of the SDG in the program is concerned, only the limits of the frequencies are left
(I have not yet been able to discover any other differences when setting the values in the mode window)
you should actually have the definitions for e.g. SDG1032X and 1062X derived from 2122 already make finished ?
regards klaus. "Art is when you can't do it ... because if you can, it's not art"
    • Tests
« Reply #404 on: April 30, 2020, 01:20:52 pm »
I may get around to do something with #metadef then.
Offline klausES
« Reply #405 on: April 30, 2020, 01:23:55 pm »
I still have to check whether I have done everything correctly, then I will send it.
Offline MikeLud
« Reply #406 on: April 30, 2020, 01:50:16 pm »
HKJ,
One thing you are missing for the modbus protocal is to have a #SlaveAddress tag
Offline klausES
« Reply #407 on: April 30, 2020, 01:54:09 pm »
MikeLud, haven't tested the new SDM3000 definition, just read it.
Could it be that in #metadef the range boundaries (up to 6 boundaries and up to 2 boundaries) were confused between the three SDMs ?
As far as I know, the ranges up to 6 were on the 3045X
(The 3055 definitely has the ... 2 as the range limits).
Offline MikeLud
« Reply #408 on: April 30, 2020, 02:05:36 pm »
klausES,
How the #metadef for each SDM works it removes the item (range) from the setup tab
    • Tests
« Reply #409 on: April 30, 2020, 02:35:11 pm »
I was very much in doubt about the slave address, my conclusion was:
When using a device on a RS232 connection there will only be one device, i.e. it can be configured as 1.
TestController cannot handle a 485 or 422 bus with multiple devices on, it needs a separate port for each device (At least for now). If TestController was handling multiple devices the address must be configured on the "Load Devices" page, not with a tag.
Offline klausES
« Reply #410 on: April 30, 2020, 05:09:13 pm »
Got SDG1062X and 1032X ready.
Also adjusted period for these two.
Should now be error free.
Oh well, the voltage display in the mode window now also works with x.x values (thank you).
You hadn't added V rms yet (this is not supposed to be a push),
but should I still upload these two SDG1000X for you?
Offline klausES
« Reply #411 on: April 30, 2020, 05:14:52 pm »
...How the #metadef for each SDM works it removes the item (range) from the setup tab
After trying it out, I understood what you meant.
SDM3055 runs with it. Thank you.
(I had to get used to the slightly different setup window. all good).  ;)
Offline Hexley
« Reply #412 on: April 30, 2020, 05:19:56 pm »
Klaus,
I am working on some changes to the SDGxxxxX device  (using an SDG1062X as a test bed). This will support setting HLEV and LLEV amplitudes as an alternative to AMP and OFFSET; also will support polarity inversion and output channel addition ("wave Combine").
If you can upload your files, perhaps I can merge these changes when they are ready.
Thanks,
Hexley
Offline klausES
« Reply #413 on: April 30, 2020, 05:20:32 pm »
Current definition for Siglent SDG1032X and SDG1062X (checked on both).
The following users thanked this post: Hexley
Offline klausES
« Reply #414 on: April 30, 2020, 05:22:18 pm »
OK. (that was almost at the same time ...)  ;D
Offline klausES
« Reply #415 on: April 30, 2020, 05:27:35 pm »
The two definitions originally come from HKJ from an SDG2122X, not mine.
I only adjusted the limits for the two SDG1000X.
    • Tests
« Reply #416 on: April 30, 2020, 06:06:45 pm »
I will stay away from the SDG's for now and wait for Hexley.
I hope he has noticed that it is not a clean SCPI device, it has some code support for the #askValues.
Offline MikeLud
« Reply #417 on: April 30, 2020, 07:56:46 pm »
Attached is a device file that supports Siglent SDM3000 series DMM in one file. The only model tested is the SDM3065X so if anyone has the SDM3045X or SDM3055 please test and let me know the issues you are having so I can correct them. One setting item I am not sure about is the Speed setting for the AC Current and AC Voltage on the SDM3045X , this was not fully documented. For each mode there is a corresponding setup tab giving you remote control of the soft buttons on the bottom of the screen.
HKJ,
So far 2 out of the 3 SDM's have been tested and are working. Do you still have the SDM3045X so you can test the last device. One setting item I am not sure about is the Speed setting for the AC Current and AC Voltage on the SDM3045X , this was not fully documented.
* SiglentSDM30xxx.txt (16.97 kB - downloaded 73 times.)
« Last Edit: April 30, 2020, 08:08:38 pm by MikeLud »
    • Tests
« Reply #418 on: April 30, 2020, 08:29:05 pm »
I will find the meter and take a look at it tomorow.
Offline klausES
« Reply #419 on: April 30, 2020, 09:20:44 pm »
A purely theoretical question (since the workload would certainly be too great ...)
Would it be possible to operate an SDG remotely like on the control panel ?
Similar to what Siglent did with its control panel in EasyDmm for the SDMs ?
There must be no feedback to display the states, which, like EasyDMM, is the same as the device display,
a display of the states in rows, columns, radio buttons would be enough.
Why this had siglent done for the SDM but never for the SDG is a mystery to me.
Offline Hexley
« Reply #420 on: April 30, 2020, 09:29:04 pm »
Is it just me, or did the page about scripting a SCSI DMM recently lose much of its content?
I need the syntax for the ":readmath:" functions, but they seem to have vanished.  :(
Offline tautech
« Reply #421 on: April 30, 2020, 10:13:38 pm »
Maybe the Equation Editor in EasyWaveX can do what you want ?
Or is it a Virtual instrument you seek ?
AFAIK Siglent have never had a virtual instrument interface for their AWG's.
Offline MikeLud
« Reply #422 on: May 01, 2020, 12:22:20 am »
Hexley,
Try this link https://lygte-info.dk/project/TestControllerConfigDevice%20UK.html#Some_functions_that_can_be_used_in_readmath
    • Tests
« Reply #423 on: May 01, 2020, 04:27:19 am »
If you mean a layout similar to the SDG control panel, the answer is definitely no. The control panels you build in TestController uses a fairly simple language and a limited amount of control elements. This works great for building a rudimentary control panel, but not for making anything remotely similar to real instrument control panel.
    • Tests
« Reply #424 on: May 01, 2020, 06:07:17 am »
The speed setting works fine on 3045, but mine do not have PT1000 (I do not know if it is a old sw version or if unsupported on 3045).
