Made.
It seems that it works with the SDG1062X.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Limits would have to be changed (e.g. sine from max. 120 MHz to max. 60 MHz for SDG1062X).
What strikes me is that the output ON / Off on channel 2 does not respond (it works on channel 1).
If I activate Output Channel 2 manually on the device, the software even shows me that, just switch from the software, because it does not respond.
And at volt it only allows pp setting, which is missing for rms.
