V2.49 is up
A couple more devices, some bugfixes, a new popup and a few internal additions.
Added: Hantek HDP4424B, Hantek HDP4424 power supplies (Thanks Microcheap)
Added: Hantek HDP4324B, Hantek HDP4324 power supplies (Thanks Microcheap)
Added: Hantek HDM3065H, HDM3055, HDM3055B, HDM3055A, HDM3055S, HDM3055H bench DMM (Thanks Microcheap)
Added: B&K Precision BCS6401 for logging and interface (Thanks Geofrey)
Added: UNI-T UDP3305S and UDP3305S-E lab power supplies (Thanks thephil)
Fixed: GridPanel/SinglePanel math channel fail when one is closed.
Fixed: Reload bug in AR488 driver (Thanks flash2b for the good logging to show the problem).
Added: MPPT (Maximum power point tracking) popup, it is fairly simple, but makes it possible to test solar panels.
Added: PrintLog to programming language, it will print to the log window
Added: Virtual harmonic generator, this is for testing TC with harmonic data.
Added: Virtual multi sinus generator, this is only for testing TC with multi channel data (up to 512).
Fixed: Block protocol on socket.
Added: Setting "Fast charting" for speeding up charting on slow machines.
Fixed: Scales for chart, decimals column was damaged in last version
Updated: Kollmorgen AKD2G servo driver (Thanks gby)
Added: Tasi TA612C 4 channel Thermocouple Logger (Thanks gby)
Updated: Rigol DP832, DP832A (Thanks Gulftown)
Added: Keithley 199 Bench DMM (No support for scanner) (Thanks Gertjan)
This popup can (together with a load) be used to log solar panel performance or compare multiple panels/placements.
