V2.06 is up
It is a mixed bag of devices and a new popup that gives a visual interface to some chart based commands.
Added: replaceRX() that is a RegEx version of the replace() function
Fixed: Riden RD6012 power supply.
Added: Riden RD6018 power supply (Thanks toddehawk)
Added: Riden DPH5005 power supply (Thanks rachdatu)
Added: Manson HCS-3404 power supply (Thanks Scheppo)
Added: East Tester ET5301 electronic load (Thanks SebiTNT)
Fixed: GridPanel color selection remembers last selected colors
Fixed: Table column width can be adjusted.
Changed: Keysight DS0X2214A to DS0X2024A, the 2214 do not exist according to WS.
Added: Keysight U1242C DMM (Thanks WS)
Added: Keysight U1211A, Keysight U1212A, Keysight U1213A Clamp meters (Thanks WS)
Changed: HP/Agilent 34401A uses handshake for more reliable RS232 communication (Thanks WS).
Added: Script generation with all settings from layout popup and a bit more to restore a chart layout.
Changed: Increased maximum number of scale from 6 to 8 due to the easy way to combine scales.
Added: Layout popup to chart, this can change colors and names, add annotations and reduce number of scales.
Added: HP E3632A, HP E3633A, HP E3634A Power supplies (Thanks WS)
Added: Support for RS232 flow control (Only fully supported on Windows)
Added: HP 6631B, HP 6632B, HP 6633B, HP 6634B Power supplies (Thanks WS)
![](https://lygte-info.dk/pic/Projects/TestController/DocChartLayout/ChartLayout1a.png)
Colors can easily be changed on different elements on a chart.
![](https://lygte-info.dk/pic/Projects/TestController/DocChartLayout/ChartLayout2a.png)
Names of the curves can be changed on the chart (these changes will only affect the chart, not anywhere else)
![](https://lygte-info.dk/pic/Projects/TestController/DocChartLayout/ChartLayout3a.png)
Combine similar scales to get more chart area, due to this I have also increased the maximum from 6 to 8 simultaneous curves.
![](https://lygte-info.dk/pic/Projects/TestController/DocChartLayout/ChartLayout4c.png)
Annotations can be added here.
![](https://lygte-info.dk/pic/Projects/TestController/DocChartLayout/ScriptGenerantion.png)
When this popup is open it is possible to generate a script with all chart settings
