V1.84 is up
A lot of small additions and fixes.
Fixed: (I hope) A problem showing script list popup
Added: Table "Goto value" value move the view to the value that is closet to specified value in column.
Added: Table goto min/max move the view to the highest/lowest value in a column.
Changed: Table numeric format selection changed to match "Current values" numeric format selection (They adjust the same global format).
Added: Numeric format can be changed on "Current values", this is a global change similar to #VALUEFORMAT command.
Added: Menus on Readout shows selected value
Added: Readout support one larger text size (This could be done from scripting, but not from menu)
Fixed: Script layout generation did not save transparency on Readout correctly
Added: "#cmdSetup multi combobox" and :string: tag support for multi control.
Added: Alarm popup can also be set on LogEvent and script done
Added: Support "Math" channels in Grid panel popup
Added: Support "Math" channels in Param sweeper popup, breaker
Added: Support "Math" channels in Log event popup
Added: Support "Math" channels in Auto hold popup
![](https://lygte-info.dk/pic/Projects/TestController/DocTable/Decimals.png)
The right click menu on the table page is changed and has some goto functions.
![](https://lygte-info.dk/pic/Projects/TestController/DocReadout/Menu1.png)
The right click menu on Readout shows what is selected and has a local format override.
