@HKJ,
Tested with version 1.68, looks good.
No dropouts seen in first tests.
Some spikes in Current value, but that can be generated by Dl24.
I always had more dropouts when I had connected DL24 and RD6012 at the same time.
See pictures.
1. Only DL24 connected.
2. DL24 and RD6012 connected. Dropouts are RD6012 values, when stressing de RD with the rotary Encoder.
3. The same as 2, but for 45 minutes, no dropouts.
4. More than 3 hours logging, not touching anything, no dropouts DL24, some spikes on current values, probably generated by DL24. Some dropouts in voltage reading RD6012.
Looks good for the moment, thanks.
