With the JL24 I do not have any good ideas. Do it connect more often now or is it the same?
It seems about the same. But I noticed a difference between DL24P and JL24. DL24P sends data once every second regularly. On the other hand, JL24 sends data 3 to 5 times every second. It's continuous and fast. I recorded short movies of Termite outputs for both.
DL24P:
https://photos.app.goo.gl/o9YzSxjNgBEb4frV8JL24:
https://photos.app.goo.gl/12FtvHFSGrgES1FS9When I save the data from both devices using Atorch E_Test software, I get something like the following. Columns are Time, Voltage, Amps, and Watts.
DL24P:
16:48:47 12.4 6.997 86.7628
16:48:48 12.4 6.998 86.7752
16:48:49 12.4 6.997 86.7628
16:48:50 12.4 7.003 86.8372
16:48:51 12.4 7.002 86.8248
16:48:52 12.4 7.002 86.8248
16:48:53 12.4 6.997 86.7628
16:48:54 12.4 7.003 86.8372
JL24:
15:05:23 112.4 5.359 604.7
15:05:24 112.4 5.359 604.6
15:05:24 112.4 5.361 604.8
15:05:24 112.4 5.361 604.9
15:05:25 112.4 5.362 604.9
15:05:25 112.4 5.362 605
15:05:26 112.4 5.363 605.1
15:05:27 112.4 5.364 605.1
15:05:27 112.4 5.363 605
15:05:27 112.4 5.364 605.2
Does this give you any clue?
Thanks,
-JK
