Author Topic: Is the DE-5000 software useful?  (Read 15995 times)
Offline JDubU
Re: Is the DE-5000 software useful?
« Reply #25 on: March 20, 2019, 09:43:19 pm »
The signal on the Rx input of your serial to USB converter board should look like the scope image below:
Note the readouts along the bottom left.  The polarity of the signal is normally high.
« Last Edit: March 20, 2019, 09:45:54 pm by JDubU »
The following users thanked this post: Calambres
Offline Calambres
    • Piso-Tones
« Reply #26 on: March 22, 2019, 09:38:46 am »
I do not see such pulses in my scope. The ones I see are AC only pulses with a few millivolts.
Something's wrong with my UART and/or phototransistor  |O
The UART board measures 4.23V in the 3.3V output so I suppose it is not working properly but I've read of many of these boards behaving this way.
Offline Calambres
    • Piso-Tones
« Reply #27 on: March 22, 2019, 01:15:54 pm »
PROBLEM SOLVED!    8)
As I didn't get any scope readings in the 3 or 4 volts magnitude as in your picture above (the pulses I got were in the millivolts range) I began to suspect the phototransistor was not working at all. In fact I ordered two L53P3C from this ebay seller (caveat emptor). None of them seem to work. I went to my local components store and bought a BPW77NB. As soon as I put it in the UART board I immediately noticed that, when attached to the DE-5000 in "PC" mode, the RX LED started flashing once every second. Now the scope reading is identical to that of JDubU's two posts up.
Now it works like a charm, providing I set up a 470R pullup resistor as JDubU stated some posts ago.
Thanks a lot to everyone helping!  :-+
« Last Edit: March 22, 2019, 01:28:39 pm by Calambres »
Offline djeans
  • Country: tr
« Reply #28 on: March 24, 2022, 08:59:39 am »
you need to add a resistor, 470 - 1k, then it will work with the most of the phototransistors. Check it with your ocilloscope.
Connect OUT to your USB RS232's RX pin
Connect to 5 V / 3.3 V (depneding on your setting on the RSR232 USB converter)
Connect GND to GND
« Last Edit: March 24, 2022, 09:02:20 am by djeans »
peace!
The following users thanked this post: pepe10000
Offline coromonadalix
« Reply #29 on: March 24, 2022, 02:40:42 pm »
I would add    the cp2102  sometime doesn't work well in recent os'es  like win10,  some prolific chipset too
I would use  ch340 or ftdi based  usb uart boards ...
but  great work  :-+
Offline pepe10000
« Reply #30 on: March 24, 2022, 05:07:40 pm »
Hello.
I wonder if someone would be so kind as to post a screenshot of the DE-5000's communications via putty:
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
I can't get my newly purchased DE-5000 to communicate with its software and I've tried everything I can think of, from using various values of Pull-Up resistors (even no resistors), different operating systems (WinXP-7-10), different computers, different IR receivers, different USB-TTL adapters, etc.
I put an image of what I captured in the PuTTY.
Unfortunately, my oscilloscope is analog and very old, but from what little I've been able to see the waveform looks a lot like some screenshots on the forum.
Thanks in advance and greetings.
Offline djeans
  • Country: tr
« Reply #31 on: March 24, 2022, 09:11:57 pm »
Hi, here it is how it does look with 9600bps 8n1. similar to yours. Therefore I'd assume you dont have a hardware problem, maybe you can uplaod a youtube video?
Dont forget to press on the play button in the software ;-)
« Last Edit: March 24, 2022, 09:33:40 pm by djeans »
peace!
Offline pepe10000
« Reply #32 on: March 25, 2022, 06:04:56 am »
Hello.
Thanks for the catches.
It works now, the problem was:
He didn't know he had to hit the play button.
I had been trying for many days, but it never occurred to me to press it.
Going to old does not compensate,  :-DD  :-DD  :-DD
I am very grateful for the help, this forum is great.
All the best.
Offline djeans
  • Country: tr
« Reply #33 on: March 25, 2022, 09:51:28 am »
hahah, thanks for the (honest) feedback.  :clap: ;D
this happened to me as well as it is not self explanatory, therefore I guessed it might be same for you.
have fun (for whatever you need it, I am not sure why I build it and if I ever will need it  :palm: )
peace!
Offline pepe10000
« Reply #34 on: March 25, 2022, 11:12:30 am »
Hello.
You're welcome.
I certainly don't plan to use the PC connection too much, normally I'll use it in portable mode, but I wanted to know what was the matter that it worked for everyone and not for me,  :-DD  :-DD  :-DD
A photo of the inside of the adapter already working.
Thank you very much and greetings.
« Last Edit: April 25, 2022, 08:13:11 am by pepe10000 »
Offline eevblogger88
« Reply #35 on: May 06, 2022, 12:17:34 pm »
https://sigrok.org/wiki/DER_EE_DE-5000
Sigrok supports it.
While that is true, we currently unfortunately have no one working on a GUI for this device class. This leaves only sigrok-cli to query device data, which means that there's no graphical display and it's up to the user to use whatever graphing tool they want to use. While flexible, it's probably not what fishandchips wants/needs.
This may of course change in the future but until someone volunteers, that's the status quo.
Update:
https://sigrok.org/wiki/SmuView
Hope my DE 5000 will work with it under MacOS, will try it next week with the "official" usb adapter
Offline buuak00
  • Country: kr
« Reply #36 on: July 15, 2024, 03:48:38 am »
I added a 10k pull-up resistor and it works.
CP2102 driver installation is difficult.
The following users thanked this post: coromonadalix
Offline Melly1971
  • Country: si
« Reply #37 on: July 24, 2024, 11:50:08 am »
Solution for L-53P3C.2320735-0
Offline Melly1971
  • Country: si
« Reply #38 on: July 31, 2024, 05:22:59 pm »
CP2102 USB to UART in Windows 10 64 bit with CP210x Universal Windows Driver v11.4.0 is recognized in device manager but not in software. With CP210x Windows Drivers v6.7.6 is working fine.
CH340G UART works fine.
Offline al777
« Reply #39 on: August 16, 2024, 09:50:40 pm »
Just to keep all the "DE-5000 IR interface" info in one thread, here is my successful setup.
I've used the PT908-7C side-looking phototransistor (not from Digikey, so no guarantees it's original - but works reliably in this use case).
Friction fit "chassis", CP2102-based USB-to-TTL UART with USB-C connector. 1kΩ resistor from RX to 3V3. It works with 10kΩ as well, and anything in between, but rising slope gets uncomfortably slow, so 1kΩ is better.
The logic low level (when PT is open) is about 800mV, a bit high per CP2102 specs, but there must be good margin there, because with different pull-up Rs I saw it at just above 1V - and CP2102 was still reliably decoding the pulses.
The logic high is around full 3V3 rail (about 3.45V).
It will work with pull-up to 5V rail as well, CP2102's max V on any IO pin is 5.8V if I recall correctly, but I took a safer route.
Drivers used are Silicon Labs' v. 11.3.0.176 (VCP drivers) - works well under Windows 11 Pro 23H2 with latest patches. To install these - download them from Silicon Labs, unpack, then go into Control Panel - Device Manager, find CP2102 there, "Update Driver", choose from local disk (point it to the folder to which you've unpacked the drivers).
The software is from IET Labs website, for DE-6000, works well, just choose which COM port the CP2102 lands on.
Don't forget to press the "Play" button in software and the "PC" button on the DE-5000 to see the results :-).
I'm attaching a strip of photos and the PT908-7C datasheet here for reference.
I hope this will help someone!
« Last Edit: August 16, 2024, 10:36:45 pm by al777 »
The following users thanked this post: ledtester
