It looks like specmaster is doing a good job of mentoring you
If something is damaged in transit, often because it is badly packed, that is grounds to reject it and get a refund. Basically the seller should pack something properly, but often they don't. If packaging looks inadequate, I take many photos as I unpack it.
With ebay the critical point is what it says in the "Condition:" box. If it says "Used"/"Refurbished" then it should work correctly to the original specification. If it says "Spares or repair" then it might or might not work. Those of us that sell test equipment on ebay really wish there was another category: "all functions work, but we cannot guarantee that it fully meets the original calibration". If I sell a multimeter I will be able to show that all the readings are sensible, but I will not be able to calibrate it to the full specification. If I marked it "refurbished" or "used", an unscrupulous buyer could use that to reclaim money from me. Hence I have to mark them "spares or repair"; shame.
FFI ebay>>help>>search for "condition"
https://www.ebay.co.uk/help/selling/listings/creating-managing-listings/item-conditions-category?id=4765&st=3&pos=1&query=Item%20conditions%20by%20category&intent=condition&lucenceai=lucenceaiI will emphasise a couple of specmaster's points.
A beginner should not attempt to repair a broken scope, unless the damage is obvious, simple, and can be easily repaired.
There will be around 2kV, possibly 8kV inside the case, stored on capacitors that can spoil your day. Gloves wouldn't be sufficient. Be very sure of all the places those voltages exist before turning it on when it is outside its case. There are other places "near the power supply" where there are dangerous voltages, but gloves might or might not help.
Do use the ebay complaints procedure correctly. It is explained well in the help sections. Give the vendor the chance to put things right, but don't allow them to "run down the clock" so that complaints are no longer possible.
Sometimes things go wrong that are outside the vendor's control. I've just had somebody complain that something I sent didn't arrive, so they asked for a refund. I'm content that they aren't lying nor trying to cheat me, so I discussed the options with them. In the end I sent duplicate goods, and they have arrived. The buyer is happy, and I'm irritated but not unhappy.
BTW, ignore anybody that says you shouldn't buy an old analogue scope but must buy a digitising scope. You will learn a lot with a
working scope, analogue or digitising, and analogue scopes are simpler for beginners to learn.
