Hello George and all,
Well a kind member of the HP/Agilent Yahoo! group sent me a few disks with the firmware on it and I was able to boot my analyzer and get working boot disks. There is a caveat however. I did have another member send me a couple of disks that made it through 90% of the boot process before it failed with a fatal error. So the user that said he got this failure it could be that the boot disks that he has are for an analyzer that has 1.XX EPROM (internal EPROM firmware, not the operating system boot) firmware and he is trying to boot the operating system version 2 or vice versa.
The operating system disk major revision level and the EPROM firmware must match. So a 1.xx EPROM and a 1.xx opsys is a go and a 2.xx EPROM and a 2.xx opsys is a go but you can not mix levels. Also 165XA and 165xB op sys disks are not interchangeable.
If you can find a true MSDOS system with real floppy (not a USB one) you can use the files from the HP/Agilent site (I put a copy up on the Yahoo! site as well for 2.xx Opsys) with the included LifUtil to make a bootable disk. But it must be a true MSDOS system as the LifUtil needs direct access to the floppy drive controller to create the files. The disc (it was disc in those days. I think disk was a made up word) sectoring IIRC is as follows: 1024Bytes, 5 sectors per track, 77 tracks, 2 sides and 144 files per side. I think an interleave of 1 or 2 will work.
Once you have a bootable disk copy it in the analyzer. The copies seem to boot faster than the LifUtil made ones (it could be my imagination but the asterisk blinks faster when the code is loading).
I have tried to use various disk imaging software but this far I have not been successful in making an image that can be recreated and also bootable on the analyzer. So when you make copies make a few.
Some useful notes:
The drives in the 165X analyzers do have a 34 pin connector but they are not pinned like modern (well 80's) PC floppy drives. The odd pins that are normally grounds are shared with +12V , +5V and ground so if you were to plug a regular 1.44MB or 720K floppy drive in there you might blow up the supply in the analyzer. I did note that the even pins seem compatible so it could be possible to make a cable that could convert the drive.
However the original drive is 600RPM vs. 300RPM (500K transfer rate). Standard 144MB drives are
