Author Topic: Tektronix 1240 ROM pack manual?  (Read 2212 times)
Offline FloopyTopic starter
  • I'm going to need another oscilloscope to fix that
« on: December 22, 2018, 11:43:54 pm »
I've searched and scoured, but have found nothing.
I have a Tek 1240 with an 12RM63 6502 disassembly cartridge. I would like to use it but I can't find a manual explaining how to hook it up. There are 5 control lines that connect somewhere. I figured one of the lines (R/W). Where I can find a manual for this cartridge? Even a manual to some other Tek 1240 ROM cartridge could shed some light.
Does such a manual exist?
-Thanks
Offline TerraHertz
    • It's not really a Blog
Re: Tektronix 1240 ROM pack manual?
« Reply #1 on: January 02, 2019, 12:17:49 pm »
What a coincidence. I've just had my 1240 out to check it. Was discussing ROM packs with user bsb0011 here.
He mentioned the Tek ROM images at http://w140.com/tekwiki/wiki/1240
There are a LOT of them, but all listed by Tek part numbers and what instrument they are for.
I'm sure many are for disassembler ROM packs, but haven't found any index of what packs used what EPROM PNs.
Tek wasn't kind enough to put any helpful identifier text IN the EPROMs.
So far I didn't find any ROM pack user manuals. Yes they did likely exist, since there is a manual for the Comms pack
The reason I have my 1240 out, is that I need a 6502 disassembly logic analyzer.
Can you tell me the Tek PNs on the EPROMs in your ROM Pack please?  And their IC numbers.
Hopefully the images are already at Tekwiki.
If not, maybe you can read and upload them?
Edit to add - I found the IEEE 488 plugin manual.
http://gamearchive.askey.org/General/Test_Equipment/
TEK Logic Analyzers
    1200 GPIB COMM pack      Manual for the 1200C02 GPIB COMM Pack for 1200 series LAs.
    1240 Operators Intro
    1240 Operators PT1
    1240 Operators PT2
    1240 Operators PT3
    1240 Operators PT4
    1240 Operators PT5
    1240 Operators PT6
    1240 Operators PT7
    1240 Operators PT8
    1240 Operators Idx
    1240 Perf Anal Pack       Performance Analysis ROM pack manual.
    1240 Service Vol2 CH0
    1240 Service Vol2 CH9
    1240 Service Vol2 CH10
    1240 Service Vol2 CH11
    1240 Service Vol2 CH12
    1241 Service
Oh and btw, why I'm looking for a Tek 1240 6502 disassembly pack, is that I'm about to try and resurrect my old Apple II, then document some 6502 disassembly and hacking I did back in 1979, of Apple DOS 3.2
Background story here: http://everist.org/NobLog/20181001_missing_wave.htm
Problem is, all the printouts I did then were on crappy thermal paper. Which has faded to almost total illegibility.
« Last Edit: January 02, 2019, 12:50:13 pm by TerraHertz »
Offline bsb0011
« Reply #2 on: January 02, 2019, 01:51:04 pm »
Here is a watered down version of what I will be posting over at the 1240 wiki page (the entire list spreads past the end of most screens, and the line wrap makes it very hard to read).
Model
Number   Description
12R01   Performance Analysis
12RC01    Line Printer Support
12RC02    Master/Slave
12RM01    8080 Microprocessor Support
12RM02    8085 Microprocessor Support
12RM03    8086 Microprocessor Support
12RM04    8088 Microprocessor Support
12RM05    80186 Microprocessor Support
12RM08    80286 Microprocessor Support
12RM21    6800 Microprocessor Support
12RM22    6802 Microprocessor Support
12RM23    6808 Microprocessor Support
12RM24    6809 Microprocessor Support
12RM25    68000 Microprocessor Support
12RM26    68008 Microprocessor Support
12RM27    68010 Microprocessor Support
12RM31    68020 Microprocessor Support
12RM33    68030 Microprocessor Support
12RM41    Z80 Microprocessor Support
12RM42    Z8001/3 Microprocessor Support
12RM43    Z8002/4   Microprocessor Support
12RM62    9450 (MIL-STD 1750A )   Microprocessor Support
12RM63    6502/65C02      Microprocessor Support
12RM71    NSC800          Microprocessor Support
12RM99    Option 01 GM ECM    Microprocessor Support
12RM99    Option 02 1802/4/5/6    Microprocessor Support
12RM99    Option 03 8031/51    Microprocessor Support
12RM99    Option 04 GPIB Bus    Support
12RM99    Option 05 6801       Microprocessor Support
12RM99    Option 06 6805E2    Microprocessor Support
12RM99    Option 07 6805E3    Microprocessor Support
12RM99    Option 08 68HC11    Microprocessor Support
12RM99    Option 09 6301/03    Microprocessor Support
12RM99    Option 11 TMS32020/C25    Microprocessor Support
12RM99    Option 12 64180R0/R1    Microprocessor Support
12RM99    Option 13 VAXBI Bus    Support
12RM99    Option 14 TMS32010    Microprocessor Support
12RM99    Option 15 DSP56000/1    Microprocessor Support
12RM99    Option 16 8096/7    Microprocessor Support
12RM99    Option 17 ADSP2100    Microprocessor Support
Hope this helps someone.
(Just noticed I can attach a file, so I'm attaching a larger file with more information.)
Offline JFJ
« Reply #3 on: January 02, 2019, 03:50:06 pm »
There are 5 control lines that connect somewhere...
The attached pdf shows the connections between a 1240 analyzer and a 6502 processor:
Offline bsb0011
« Reply #4 on: January 02, 2019, 07:11:07 pm »
Good info!  I noticed that the table looked like it was page 3 of a document, is there any chance you have the rest of this document, or any other connection diagrams for other processors?  I am going to be doing a update on the wiki listed at a link above pretty soon, and I would love to include any information that I can.  It seems that the information for the Tektronix 1240 / 1241 logic analyzer is spread pretty thin out in the wild, and I'd like to collect it all into one spot for others to find easily.
If anyone else has any information on the Tektronix 1240 / 1241 it would be great if you would contact me, so I can get all that updated.
As I do not have anything else to contribute to the 6802 in regards to the 1240, I'm going to start a new thread to collect any information on the 1240 /1241, and return this thread to the OP.
Offline JFJ
« Reply #5 on: January 02, 2019, 08:53:51 pm »
Sorry, the 6502 pdf table is exactly as I downloaded it, several years ago.
However, I do have full instructions for the 8080, 8085, 8088, 80186 and Z80 processor ROM packs. Also, I have the instructions for the 12RM99 ROM pack (which can be programmed for any processor). I will attach the files to your new thread.
