Author Topic: Precision trimmers Bourns 3296 vs 3299  (Read 5696 times)
Offline Mr SimpletonTopic starter
  • Not the sharpest knife in the drawer
« on: September 21, 2015, 08:58:01 am »
I am currently renovating  several PTS1000 signal generators, and they use 50 (fifty) Bourns 3299 trimmers for coarse setting of VCO
Now the 3299-serise seems to be a lot more expensive and harder to find (at least "my" values) vs the 3296-series
Reading data sheets, it seems it is a drop-in replacement as the only difference seems to be a thinner housing on the 3296. But is there any advantage to keep looking for 3299-potentiometers? Key parameters are noise and keeping performance over time.
I rather do this right the first time. Not too fun replacing 50 pots.... on ten units. Leave the math for the reader :D
Should add: The PTS1000 comes with the 3299.. hence the query  :o
« Last Edit: September 21, 2015, 12:38:27 pm by Mr Simpleton »
Offline Psi
Re: Precision trimmers Bourns 3296 vs 3299
« Reply #1 on: September 21, 2015, 10:01:43 am »
Looks identical to me, other than the size as you say.
Offline markce
« Reply #2 on: September 21, 2015, 05:11:29 pm »
900VAC - 600VAC, 25 turn - 12 turn. Contact resistance variation 1% - 3%
The 3299 is more precise the 3296 more enduring (temp, vibration).
« Reply #3 on: September 22, 2015, 09:43:11 am »
@Markce Not sure where you found those specs.... I had a look at:
http://www.bourns.com/data/global/pdfs/3296.pdf
and
http://www.bourns.com/data/global/pdfs/3299.pdf
They look pretty identical except for weight and size!
I still have to make sure the 3296 is just as good as the 3299, the size is smaller and will fit the PCB, I just have to be sure it will be performing like the 3299 (or better :) ) BTW the 3296 seems to be MIL-listed.
Cheers
Offline markce
« Reply #4 on: September 22, 2015, 10:48:20 am »
It's in the left column under 'Electrical Characteristics'.
« Last Edit: September 23, 2015, 08:41:58 am by markce »
« Reply #5 on: September 22, 2015, 12:16:19 pm »
Not trying to be a smart alec...
I see no electrical difference between these two... both are 25 turns and both shows 900VAC dielectrical strength, if looking at the PDF-links I posted.
Are there other specs available that differ the data sheet?  :scared:
Offline markce
« Reply #6 on: September 22, 2015, 04:09:46 pm »
My 3269 datasheet is for the X style, which is the current product I found. Yours is for the W style, and these apparently also differ electrically. Found the Bourns trimpot catalog on the Farnell site.
http://www.farnell.com/datasheets/681515.pdf
« Last Edit: September 23, 2015, 08:43:18 am by markce »
« Reply #7 on: September 22, 2015, 07:50:54 pm »
@Markce, are you aware that we discuss 3296 vs 3299 not 3269  :-//
BTW all my docs are straight from Bourns... not a retailer  :-+
Offline dacman
« Reply #8 on: September 22, 2015, 11:01:31 pm »
I'd use them, but what I'd be concerned with is would the 3296 rock on the board due to it being narrower.  A cross for the 3299 used to be the 68 series, although its data sheet presently states that it has 20 electrical turns.
Offline markce
« Reply #9 on: September 22, 2015, 11:16:28 pm »
Sorry, seems to be a typo when searching initially...
« Last Edit: September 22, 2015, 11:52:15 pm by markce »
« Reply #10 on: September 23, 2015, 09:05:22 am »
Thanks for all information.... not sure it is economical viable to use the 3299 series, it seems to be 2-3 times more expensive and longer lead times. I have to settle for the 3296 and try to secure from vibrations.
Cheers
