Author Topic: Tektronix Overachiever scope  (Read 4822 times)
Offline Pat PendingTopic starter
« on: January 08, 2014, 07:19:48 pm »
http://www.tektronixoverachiever.com/
Looks like a very nice scope.
« Last Edit: January 08, 2014, 07:33:12 pm by Pat Pending »
Offline Rerouter
Re: Tektronix Overachiever scope
« Reply #1 on: January 08, 2014, 07:34:46 pm »
cannot download the datasheet off there site, and they dont make it easy to get to the manual (you have to sign up and log in)  :-\ without either of these you cant really go comparing it against a similar scope in an oranges to oranges kind of way
Offline grumpydoc
« Reply #2 on: January 08, 2014, 07:46:27 pm »
I don't think you need to be registered to see the data-sheet which is at http://www.tek.com/datasheet/mso2000b-dpo2000b-series
Offline marshallh
    • retroactive
« Reply #3 on: January 08, 2014, 07:52:44 pm »
Looks like just a 'B' revision of the same scope they've sold for years... It "works" but is a mess to use, bogs down easily and will lock up periodically.
Verilog tips
BGA soldering intro
Offline leppie
« Reply #4 on: January 08, 2014, 08:00:36 pm »
The Rigol DS1074Z seems to better in every way at half the price.
Am I missing something?
Offline marshallh
    • retroactive
« Reply #5 on: January 08, 2014, 08:06:31 pm »
If I wanted to buy a scope that would last 5 years with no problems, I would buy the Tek. It would be a bit more frustrating but reliable. No overclocked ADCs like in the *cough* other one
Verilog tips
BGA soldering intro
Offline Sebastian
  • Country: at
« Reply #6 on: January 08, 2014, 08:12:15 pm »
The Rigol is better Bang per Buck for sure but the Tektronix has more serial trigger and decoding options, you can easily use differential probes because it has the Tektronix Interface at the BNC ports and there is a MSO version.
Offline Hydrawerk
« Reply #7 on: January 08, 2014, 09:08:34 pm »
Even the B revision is old. This web http://www.tektronixoverachiever.com/ is not new at all. Yes, MSO2000 has some advantages over my DSOX2002A. It has a bit longer memory, more triggers, better search capabilities, active probes...
But the screen is small. No pushable knobs. No TrigOut BNC. No function generator. Probably no table function for serial decoding. Well, this was decent scope in 2008.
Please note that the product videos were made in october 2012.
« Last Edit: January 08, 2014, 09:10:41 pm by Hydrawerk »
Offline w2aew
    • My YouTube Channel
« Reply #8 on: January 08, 2014, 09:32:41 pm »
Really?  I've been using these scopes for a while, and find them very intuitive to use, never had one lock up, and they only slow down when you ask them to do something like a search or decode on a long record.  Very nice little scopes.
FAE for Tektronix
Offline marshallh
    • retroactive
« Reply #9 on: January 08, 2014, 09:47:42 pm »
I may be spoiled by Agilents, but the ones I used didn't impress me very much, though they did work. It's possible the unit had an older firmware and the newer ones are better in that respect. I won't ever turn down an opportunity to demo units :)
Verilog tips
BGA soldering intro
Online nctnico
« Reply #10 on: January 08, 2014, 10:11:01 pm »
A fixed samplerate.  The DS1000Z reduces the samplerate to 250Ms/s when 4 channels are enabled.
@marshallh: I wouldn't worry about overclocked ADCs. Rigol has done this for as long as they existed. If there where problems they would have gone belly up by now. Tektronix has oscilloscope models where components are pushed beyond their limits resulting in early failures (the trigger chip in the TDS694C for example).
« Last Edit: January 08, 2014, 10:56:04 pm by nctnico »
Offline Hydrawerk
« Reply #11 on: January 08, 2014, 10:33:13 pm »
At first glance the DPO2000 was uneasy to operate for me. The display is overcrowded with stuff. It is rather small, but it has buttons on bottom and on right. BTW my friend has that scope and he finds it OK. (For his specific needs.) Here is teardown, not made my me. I found that photos somewhere. https://plus.google.com/photos/106264218831814439783/albums/5877858521093564545?banner=pwa
