Author Topic: Power Supply: LeCroy T3PS43203P vs Instek GPP-4323?  (Read 2163 times)
Offline PlasmateurTopic starter
« on: November 12, 2019, 06:55:26 am »
Here are the links,
1.)Lecory
2.)Instek
So is the only difference between these is that the Lecroy is a linear power supply, and the Instek is a switching power supply? They look identical.
The linear is showing up as $230 more, which I don't mind if it means there's less of a chance of me picking up high frequency noise.
Have more recent bench switching power supplies been designed to eliminate HF noise? Perhaps I should just play it safe and go with the more expensive option?
Offline 2N3055
  • Country: hr
Re: Power Supply: LeCroy T3PS43203P vs Instek GPP-4323?
« Reply #1 on: November 12, 2019, 07:29:49 am »
Here are the links,
1.)Lecory
2.)Instek
They are both exactly the same GW Instek PSU. LeCroy is rebadge...
« Reply #2 on: November 12, 2019, 03:08:01 pm »
Here are the links,
1.)Lecory
2.)Instek
I'm confused, I can't seem to find information about the GW Instek PSU being a linear power supply
Offline 2N3055
  • Country: hr
« Reply #3 on: November 12, 2019, 03:29:05 pm »
It has 350uV noise...  it is linear....
