Here are the links,
1.)
Lecory2.)
InstekSo is the only difference between these is that the Lecroy is a linear power supply, and the Instek is a switching power supply? They look identical.
The linear is showing up as $230 more, which I don't mind if it means there's less of a chance of me picking up high frequency noise.
Have more recent bench switching power supplies been designed to eliminate HF noise? Perhaps I should just play it safe and go with the more expensive option?
