You should not blindingly believe every misinformation posted in this forum.
Average and ERES as Acquisition modes
While it’s true that LeCroy DSOs never destroy the original sample data (for a reason!), hence will not have alternative acquisition modes like Peak Detect, Average or ERES, the same is not true for Siglent.
Every contemporary Siglent DSO except for the SDS2000X Plus has four true acquisition modes: Normal, Peak Detect, Average, ERES. For the time being, at least the SDS6000 provides Avg and ERES as math functions as well. Consequently, with a Siglent SDS6000 you have the choice, if you want it quick and dirty (acquisition mode) or the scientific way (math function) where you can apply it individually to each channel, even both at the same time thanks to the formula editor, and still have the unaffected original sample data available for different analysis purposes.
Long trigger delay
Long trigger delays, together with peak detect were the crouches required in some memoryless storage scopes in the past and even today. Do you really need ridiculously long trigger delays in a DSO where you can have up to 500 Mpts record length?
The SDS6000 can use 1 second of trigger delay at a time base of 100 µs/div. That is a 1:10000 ratio, just like LeCroy. You can still use the zoom mode, where you could go down as low as 100 ps/div.
Zone Trigger
Isn’t it funny how the same sources that spread false information about Average and ERES acquisition and warn about being limited to “only” 5000 (actually 10000) times the time base setting for the trigger delay forget to mention goodies like zone trigger at the same time?
What is more likely that professionals in need of an upper midrange DSO will be missing – a ridiculously long trigger delay or a zone trigger? Or a DSO that can have up to 500 Mpts record length, for that matter.
Likewise, could professionals who need an upper midrange DSO maybe take advantage on 2 GHz bandwidth and true 12-bit(*) converters? And a sample rate, that remains constant no matter what channels are activated?
(*) Even when we get only 8 bits, we still benefit from the linearity of a 12-bit ADC, so the high resolution modes up to 16 bits should work very well.
About bundle pricing: The Siglent comes as a fairly complete package, no need to pay extra for all the basic stuff like basic protocol triggers and decoders (UART, SPI, I2C, CAN, LIN) or History and Segmented Memory. Even Frequency Response Analysis comes for free. For all the rest, I think the options are priced quite reasonably.
EDIT: Clarification on the 12-bit ADC.
